Show off your single turbo engine bay
Slow335is
89
Minneapolis Minnesota
www.youtube.com
Single turbo 335is
Here is mine I’m not done yet missing my M18 intake manifold and my custom intake manifold which will make it look way better.
Reactions: MooreBoost
iminhell1
419
207
What did you guys do with the vacuum line coming off the vacuum pump?
Just cap the 2 lines to the solenoids?
Or build a new line to the booster?
birrcrin
35
23
You can remove the hose coming from the vacuum pump and make a new line with the top hose. I removed the hard plastic hose from the attachments by heating it up and used 3/8 hose with a 3/8x1/4x3/8 tee fitting and a 3/8 to 1/4 adapter for the small hose next to the power steering reservoir.
iminhell1
419
207
Making new was my plan.
The damn thing is always in the way already and now that it's exposed it's time to move it.
twinturbos
291
79
E92 335i MT
Cut mine off the fitting on the vacuum pump and just put a hose that goes right to the brake booster.
Blaster3500
296
247
SC
If anyone is looking for a good reasonably priced quality hosewith an OE look, I used Contitech N203741. Obviously setup a little different because twins. As others have done I used the upper 90 straight and the vac pump. Ignore the dirty bay.
twinturbos
291
79
E92 335i MT
Up! Anyone running a custom expansion tank ?
This is the misfire cans I haven’t Moved any lines
Where do the lines from your catch cans go ? Intake manifold and VTA ?
This is what mine looks like now with the shaved and powdercoated m18 valve cover.
OverkillGarage
14
23
Broken Arrow, OK
07 BMW 335i
Just finished the install last weekend.
**For those that have done the 335d coolant tank conversion with the associated charge pipe. I followed what someone else had done reusing the factory connectors and swapping hoses but its not fitting well. Maybe share some pictures or thread reference if available.**
