Ad: SHARP CUSTOMS N54 Group buy Thread Part 2
Sharp
26
44
Tampa
Ok guys i went ahead and ordered 20. I Payed up front for them. Once there in I'll post up and send out ones that are payed. interest was way down this time around, but I will keep them in stock this year.
4,345
The orders seemed to trickle in last time after the initial rush. Its a bargain so I anticipate they will continue to trickle in as more and more people put them on the road.
St3v3nn54
17
10
E90 330i & E92 335i
There is some guy on FB who is "doing the community a favor" and running a group buy for 450 he thinks 550 is to much.
St3v3nn54
17
10
E90 330i & E92 335i
But regardless thank you for putting the money up for 20 pieces so we can get them asap.
Can someone confirm for me what injectors they will be running.
St3v3nn54
17
10
E90 330i & E92 335i
They use EV14/EV6 injectors. The same LS injectors that the rest of the platform uses for the sandwich plate rails.
Thank you for the info, my manifold came in yesterday it looks great, I attached a photo of the test fit.
I was warned against buying injectors on ebay, and was referred here.
https://fuelinjectorconnection.com/products/fic-bosch-52lb-550cc-high-impedance
St3v3nn54
17
10
E90 330i & E92 335i
Does it rub anywhere?
Does not clears the oil filter housing no problem, can probably get away with out even changing the vacuum line from the vacuum pump.
Plumbing the fuel into the rear of the rail is super tight ordered one of these to try make the bend without trimming the plastics.
