Servotronic on a 335i
hollracing
48
44
either disable pre_usc coding in dsc or switch to 1m/m3 dsc firmware
Neg89 was asking for e89 z4 which I believe has bosch? DSC and uses DSC_89.Cxx.? Hence why I asked for coding index. But it obviously won't work with 1M/M3 firmware.
With e8/9x mk60e5 you can correct this without converting to 1M/M3 firmware…
By coding it to use, and with a custom Lenkwinkel Kenlinnie (LWK)...
You need to set C0x_LENKWINKELKENNLINIE - STEERING ANGLE CHARACTERISTIC CURVE (address 0x30000D mask 0x07) to 0x01 which tells it to use a custom LWK.
The custom LWK is coded with C0x_LWK_X2, X3, X4, Y1, Y2, Y3, Y4 (address's 0x300029 to 0x30002F).
The x-axis is steering wheel angle [DEG=DATA] with X1=0degrees
The y-axis is steering ratio [RATIO:1=DATA/10]
To interpolate the values the correct method is described in patent DE10336046A1.
But you can get good results just using more normal forms of interpolation.
You will want to map this to your specific setup as it will vary with differing alignments and suspension components etc. because of the double jointed swivel bearing setup, using turn tables or similar device for measuring the steered angle of each front wheel at the reported steering wheel angle then calculate the mean steered angle (the vehicle model in use is a single track/bicycle model (einspumodell (ESM))) and then calculate the ratio for it at the steering wheel angles you have mapped.
This works for both e8/9x non-m & 1M/M3
This can then be used (as BMW does) to tune the system between oversteer & understeer...
Your welcome
Reactions: dzid_
dzid_
54
36
US
135i 2011 DCT
I have that enabled and I don't have any problem that I can notice with DSC.
@hollracing very interesting
After analyzing the patent, I think their function has very little to do with normal interpolation.
Only two middle points P2, P3 intersect the curve! The two endpoints P1, P4 only control the curvature.
Using linear interpolation instead will be correct only for the two middle points. Which in fact may be enough, as we will see below.
I took values from NCSDummy MK60_87.C0F (LWK X and Y - wert_02 for each point).
I assumed X1 as 0, since it was not present in ncsdummy. The resulting interpolated curve only makes sense between P2 and P3. 160 seems good; it could represent 16 ratio from E90.
It's also ok if I extrapolate using their modified extrapolation method for data below P2 (G1 = 0).
Above P3, on the other hand, values quickly go to negative thousands, so no point showing.
Oh, and wert_03 (E87) values from LWK also didn't look sensible.
A lot of guessing on my side on how this is supposed to work overall...
But since values from wert_02 look plausible after plugging them into the algorithm, my best bet is to scale them by 12.5/16 to get M3 ratio curve.
So from E90?? rack C0x_LWK:
X hex0x00x50x140x86
Y hex0xB90xB00xA10x92
M3 rack C0x_LWK could be:
X hex0x00x50x140x86
Y hex0x910x890x7D0x72
  • DE10336046A1 translated.pdf
hollracing
48
44
Just use excel or similar and more normal interpolation.
Remember the steering ratio's bmw quotes are quoted as average overall ratios... non-m and M3 rack's have variable gear ratios and both use the double pivot front suspension system. Hence the need for a characteristic curve rather than just inputting a fixed ratio.
I need to map my own 135i, I originally measured a e92 m3 before my car was back together but lost this data with everything else that was on that laptop.
So I just started with the guestimate below ("E82 M3-rack test") and used logging and just tweaked it until the intervention was close enough to when and where I wanted it. But I really need to measure it so I can get it more accurate, the key is where the steering wheel angle points are...
This is the data that's there for specific models in the varying mk60e5 coding index's and my original starting point/guesstimate:
(I thought at the time for some reason M3 steering's average overall ratio was 12.6 and based it of the E81 !AFS data hence it averages to 12.6:1).
Alpina degAlpina ratio decAlpina ratio:1E87 degE87 ratio decE87 ratio:1E81 AFS degE81 AFS ratio decE81 AFS ratio:1E81!AFS degE81!AFS ratio decE81 !AFS ratio:1E82 M3-rack test degE82 M3-rack test ratio decE82 M3-rack test1 ratio:1
0​
185​
18.5​
0​
183​
18.3​
0​
162​
16.2​
0​
183​
18.3​
0​
149​
14.9​
5​
176​
17.6​
6​
162​
16.2​
21​
152​
15.2​
6​
162​
16.2​
6​
128​
12.8​
20​
161​
16.1​
62​
156​
15.6​
55​
140​
14​
62​
157​
15.7​
62​
123​
12.3​
134​
146​
14.6​
136​
139​
13.9​
115​
121​
12.1​
116​
139​
13.9​
116​
105​
10.5​
Ratio is the vertical axis here.
PRE_USC is the main difference between non-m and 1M/M3 DSC, and the biggest difference between DTC and MDM.
With PRE_USC aktiv - USC intervention is when the vehicle is going to become unstable. E.g. before the rear wheels start to slip.
With PRE_USC nicht_aktiv intervention is only when the vehicle has become unstable. E.g. Only once the rear wheels have started to slip.
Anything labeled in coding as PRE is pre/preventative/proactive/prior to etc. E.g. PRE_MSR
USC is Under/Oversteer Control (Unter/Ueber Steuern Control).
PRE_USC effects the USC Coefficient's, hence non-m DSC typically have lower USC coefficient's than M...
Reactions: Xantor and dzid_
dzid_
54
36
US
135i 2011 DCT
It's all very informative.
The curves look reasonable using the normal plotting that you did.
I think we should get rid of the notion that the controller uses the algorithm from the patent DE10336046A, because with it curves would look much different:
Either way, taking E81 and scaling it using ratios, seems like a good starting point. Excited to try it out :)
EDIT: I tried the coding.
I used E81 !AFS values multiplied by 12.5/16:
X dec0662136
Y dec143127123109
I drove it on the road and it felt normal.
Edit 2: I drove more with DTC not pressed. The car feels that it rotate itself more into the turn. It almost wants to oversteer. It's probably pre_usc doing it.
Bnks334
530
344
I've had an M3 rack in my car for ~4 years now. For about the past two years I have had the "M" module and coding for servo. The assist is fine for me as is. i am not really interested in "tuning" it. However, I have been noticing a problem. My assist seems to be "cutting out" at times. Anyone ever experience this? I want to say it might be the servo valve on the rack failing? I've double checked my wiring and that seems fine. Even remade the connections just in case. I'd have some sort of error if it was the JBBF, right?
dzid_
54
36
US
135i 2011 DCT
Do you have any errors on OBD? It can cut out if one of wheel speed sensor is faulty. But you would see traction control ⚠️ in the dash in
Btw, above post are not about tuning of the rack assist, but the correct steering ratio curve for the traction control.
Bnks334
530
344
true. I think people have discussed both in the thread. I don't ever use traction control with this car and I've never noticed it doing anything odd on the street just driving like a normal human being.
I don't have any trouble codes. I am thinking maybe the little motor is dying or the JBBF module is dying. It's definitely providing varying levels of assist which is a bit unnerving.
Boby335i n55
Hi. I got issues with servotronic retrofit. Soon as edc getting coded to jbbf servo stop working. Can you have a look for me please I got computer. Whe can do reemote. Thank you!
AzNdevil
605
291
Hong Kong
m jbbf? jbbf enabled through adding VO and default code or just enabled with ncsdummy/ncsexpert?
KClemente
315
171
E90 335i
I believe JBBF can only control either edc or servotronic. M3 DME controls servotronic which allows JBBF to control edc
Reactions: Xantor
Xantor
46
10
That's correct. The pwm signal of the jbbf either controls the edc or the servotronic. That's why I went with superwofys solution of adding a svt70 module
Marc_1980
A few months ago I fitted an M3 steering rack to my 2006 E87 130i. After that I have been trying to get the servotronic working, but without any luck until now. The refurbished M3 steering rack I bought didn't have a servotronic valve fitted, so I bought one off eBay. The eBay add said it was from a BMW E63, so I believe it should be 3210 6788658. But I don't know how to verify if it's a correct one, as the part number is not written on the actual valve.
I also wired in the servotronic valve to pins 5 and 6 of the JBFFE, and I upgraded the JBBFE to a JBFFE IIIR, part number 6135 9364819-03 with an M stamp. With the new JBFFE fitted I also needed to rewire the OBD2 part, which is also done.
I then started coding the car. I changed the build date to 0908 in the VO and added $216 to the VO. I activated servotronic in the JBBFE and tried to active the 3 parameters in the kombi. That didn't work as my kombi was a version that didn't have those parameters. So I upgraded the kombi as well to a newer/higher version that does have the 3 parameters., so those are now active as well.
But after upgrading the kombi I get an error like this:
I read the car for errors and I get A735 and A736, which says something is wrong with the servotronic, but what exactly is unclear to me.
I measured the resistance on pins 5 and 6 of the JBFFE to the servotronic valve and I get around ~7.5 Ohm, so there is no short or a wire break in the wiring to the servotronic valve, plus it seems a reasonable number to me for a working valve. But this leaves me without any ideas what the actual problem is.
As I said before, I'm unsure if the servotronic valve is the correct one. Ideally I'd use one from a E9x with Xdrive, which I believe should be the 3210 6788212, as those should be powered by the same JBFFE. But since the servotronic valves don't have the part number printed on them, I don't know which one would be correct.
Any help would be greatly appreciated!
Edit: I actually found the problem not long after posting. I wired in the servotronic valve to the wrong pins on the JBFFE. I put them on pins 24 and 25 (I think), the pins in front/behind pins 5 and 6. :sweatsmile: After correcting it the errors are gone and servotronic is working! :sunglasses:
Reactions: AzNdevil
AzNdevil
605
291
Hong Kong
interesting that you didnt have to wire your car for d-can to be able to talk to the jbbfe as this is how lci cars are wired
as long as it works ;)
Marc_1980
I actually did rewire the car for d-can. As soon as I put the new JBFFE in, I was no longer able to connect to the car, so it had to be rewired.
Reactions: AzNdevil
Boony
E90 n54 335i
Hey guys, back after a very long hiatus on this job as life gets busy and I just got used to the stiff steering. Just did a suspension refresh and thought of this again randomly. Started at the top again, didn't even realize I posted here before and already had the proper JBBFE3 with the M stamp in storage!
I have just created all the necessary materials today. Totally forgot how to code a new module so I'm refreshing on Youtube. I also do have Bimmergeeks Protool app with both licenses. I believe I can totally skip using BMW Standard Tools on my laptop and just use the app, although I do have it up and running properly on an M1 Macbook Pro using VMWare...
Couple questions.
-Since my car is an 02/07 build date, I heard my current JBBFE X14271 and X14272 harnesse connectors are switched?
-When I go to swap to this JBBFE 3, of course I match blue with blue and black with black?
-Since I have an older model, do I still need to populate any missing fuses?
-Since my car is KCAN, are pins 6 and 14 not populated on my OBD2 port, and when I do the addition of pin 6 and 14 to the X14271 it automatically switches to DCAN?
My steps are:
1. Connect the servotronic motor on the rack with my cable on the right going through the DME box and firewall grommet with black/brown to pin seat 5, and black/white pin to seat 6 on X14270 connector.
2. With the left cable, populate pin seat 6 on OBD2 to pin seat 17 in X14271 and populate pin seat 14 on OBD2 to pin seat 33 in X14271. X14271 is the BLUE connector, regardless of which side it's on the module. I will wrap this cable through the dash area behind the navi and radio.
Just read earlier in the thread I can actually "run a new cable from pin 17 on the X14271 to pin 6 on the OBD2 plug, Then swapped pin 7 on the OBD2 to pin 14" essentially running one new line.
3. Open up Bimmergeek protools and change vehicle production date to March 2010.
4. Then write write default $VO and VIN from my other module (CAS) which you pull information and select junction box to write said information?
5. Profit?
Still trying to figure out the coding part, but atleast hardware is squared away today.
AzNdevil
605
291
Hong Kong
Couple questions.
its the same connector for all build dates
yes
rack motor is powered directly from jbbf
it switches after your recode the jbbf with a newer build date iirc
My steps are:
write VO to either CAS or FRM, choose the module to read VO from inside protools, completely exit and reopen protools, code jbbf
5. Profit?
just remember to choose the correct module (CAS or FRM) to read VO from in the future depending on which module you will recode or else you will run into more head scratching
