Should ik make a log on low rpm??I will do that this evening. I have no error codes
Shadow code lpfp
Shadow code lpfp
What you have there isn't the same that others are suffering so the fixes that are incorporated into MHD aren't going to solve that.
It still looks like Lambda stimulation though so probably also caused by a diagnostic routine. Do you have any error codes?
If you unzip the file I've attached and drop it in the MHD root folder and go into the MHD logging settings you should now be able to log 3 extra channels. Bank 1 AFR Target, Bank 2 AFR Target and Bank 1 Stimulation. Tick these and also add the Fuel Mode parameter. Your next log should then give some additional detail. This will tell you exactly what AFR the DME is targeting and also the value of the diagnostic routines stimulation.
I posted 2 logs a long and short one. In the short one it happened.
Ok that's a routine that adds a loading onto the fuel trims to cause the change in lambda. You can see the dme target doesn't change at all.I posted 2 logs a long and short one. In the short one it happened.
Thanks!! For the help.Ok that's a routine that adds a loading onto the fuel trims to cause the change in lambda. You can see the dme target doesn't change at all.
I'll get some more parameters for you to try on the weekend when I'm home.
Today I reset adaptations values with Inpa.Thanks!! For the help.![]()
Add these 2 extra channels. These are the status flags for lean and rich trim stimulation.Thanks!! For the help.
What are they called in MHDAdd these 2 extra channels. These are the status flags for lean and rich trim stimulation.
under what name can I find them in options mhdAdd these 2 extra channels. These are the status flags for lean and rich trim stimulation.
Forgotten already. Something like bank 1 stft rich and lean.What are they called in MHD
I have them. Because I reset intake mass flow it’s oké for now. Wait until it’s back or just make a log? And in low rpm again?Forgotten already. Something like bank 1 stft rich and lean.
Doesn't matter too much. Just do a normal drive and log the whole thing, your commute would be fine.I have them. Because I reset intake mass flow it’s oké for now. Wait until it’s back or just make a log? And in low rpm again?
Oké will do tomorrowDoesn't matter too much. Just do a normal drive and log the whole thing, your commute would be fine.
Do you need the log. Or do you want to know what happens with bank1 to rich to lean.Oké will do tomorrow
Log would be useful. If those flags show nothing then maybe the issue isn't with the DME but with the sensor signal coming from the O2 sensors.Do you need the log. Or do you want to know what happens with bank1 to rich to lean.
Because they stay the whole time at 0
I'm not seeing the same issue in that log. The AFR looks a little unsteady after the pull but not the same issue as you had earlier.
Then I have to wait till it comes back and then make a log. Unfortunately it will.I'm not seeing the same issue in that log. The AFR looks a little unsteady after the pull but not the same issue as you had earlier.
You'd need a log showing the swaying AFR readings sway in steady driving state.
By idling the o2 sensorThen I have to wait till it comes back and then make a log. Unfortunately it will.
today my mechanic read the voltage values of the 02 sensor. After the cat the o2 sensors don’t give the same value. One stay’s 0.8 by idling and the other one fluctuatesThen I have to wait till it comes back and then make a log. Unfortunately it will.
