Will this work with the M3 strut brace?
If it shares the same profile as the 335 strut brace then yes.
Love this! Put me down for a BMS and Mishimoto with standard hardware.
Rob, put me down for 2x mishimoto brackets not one of each as you have now. thanks
I can volunteer to beta test this on the M3 strut bar![]()
We had finally sent these off this week to the 3rd party fitment tester. Just a simple LHD 335 guy so far.
Something tells me it will not work for any 1 series due to the placement of the strut bar, and for the M3 bar all we need to know if it has the same shape then it will still work per vehicle model. If not ideally the shape is not drastically different and perhaps (if the interest is there) we can make another of the same part but with the shape corrected to match the M3 bar too. If it requires an entirely new design due to an extremely different shape then us making another from the ground up is highly unlikely, we put way too much time into this thing which could still end up going no where lol.
Thanks,
Rob
BMS does not have a different can between the 1 and 3 series so I would he 99% sure you are good to go.Can anyone confirm fitment on a 1 series oem diagonal strut bar? The part numbers are indeed different between 1 and 3 series. I am theorizing and hoping that the only difference is the length with the profile being the same between the two. I am running a cowl delete so I believe that conflict will not affect me.
