PSP 900ic with 3" lower CP
The Convert
1,487
1,053
I believe you, so why is everyone worrying so much? This is high on my "next move list".
It sounds like the 335is has less room maybe? Dunno. Wasn't a big deal for me. I just bought some mandrel bends and cut, fit, weld, repeat.
The Convert
1,487
1,053
First awesome job on the charge that looks pretty good there @The Convert. Second is off topic sorry guys but I have two questions for @The Convert.
1. Are you monitoring crankcase pressure in this picture?
2. Where is the oil catch can hose running too on the passed get side(right)?
1. Good eye. I am. I was running my boost gauge to the oem crankcase vacuum oil cap piece. Turns out we get positive pressure in the crankcase with single kits at least(never checked with stock twins). Not much, but any is more than we are supposed to have.
2. I'm running a Motiv single kit, but have the same filter as my old bottom mount fftec single kit on instead of the inlet tube provided with the motiv kit. So, I made a plate with a tube that the catch can hose runs to for vacuum under boost. I have not tested this though, just copied the idea from my fftec kit. In the future, I'll probably tap the catch can and run my boost gauge to it to see if it is actually pulling any vacuum.
TwinTurboWAWD
30
12
09 335i xDrive
I think my crankcase adapter for the diesel engines I work on will fit. I'll try it
RSL
503
Very nice job. Home brew/custom fit would be easier to squeeze in, do what you gotta to do to make it fit. OTS/pre-fabbed pipe is why I was looking for confirmation, it is what it is. I have a TIG, but getting lazy in my old age. If I spent money on a FMIC with piping, I'd rather the piping just fit without needing to modify it at this point.
Yep, 335is would need KY and a shoe horn by comparison. There are multiple formed hoses/lines there that create a space the lower IC pipe needs to fit through. Can't see in this pic, but there are 2 more on the engine side and the passenger side and even this 2.75" silicone hose is squeezed on 2-3 of them.
The Convert
1,487
1,053
View attachment 9495 Very nice job. Home brew/custom fit would be easier to squeeze in, do what you gotta to do to make it fit. OTS/pre-fabbed pipe is why I was looking for confirmation, it is what it is. I have a TIG, but getting lazy in my old age. If I spent money on a FMIC with piping, I'd rather the piping just fit without needing to modify it at this point.
Looks like the bigger issue with fitment is the driver's side inlets. Moves those to the passenger's side and you free up a good bit of space.
boostE92d
150
86
Houston TX
12 335is
Ahh, I see. I don't have the ability to Fab pipes for my self, and I'm trying to avoid going too far from stock-looking. This isn't in my near future apparently.
RSL
503
It’s the angle of the picture. There’s room up top, but ST or hot side inlets would make even more. The inlet clears the 3” charge pipe with room to spare at the closest point, so definitely less concerned about that area than the places the IC hose is already hitting.
4,345
Not to continue the off topic, but if it wasn't mentioned, what PCV setup and catch can are you running?
The Convert
1,487
1,053
Oem flapper to BMS can to fftec style filter on motiv ST. RB valve on the low pressure side. That's it so far. Haven't seen enough real data on externalizing the low load side to follow suit yet.
2,198
Hey do you know of an off the shelf product that I can use to modify a BMS filter so I can attach a hose to it? Or a ST filter I can buy already designed that way and still fits on a VM/ACF top mount? Asking for my buddy.
I can probably hack something together at the hardware store but if there is something off the shelf I would prefer that.
The Convert
1,487
1,053
I don't know of anything. Fftec may make you one if you call them up?
2,198
I'll give it a shot. My only fear is their existing filter may be too large and not fit the top mount. I wonder if it is worth the hassle to send them mine...I think it's likely going to be a home depot solution...I just really don't want to use to use a nut on the side of the filter that could come loose and be eaten by a turbo...
Who knows maybe I will just cut an X insert something similar(but larger) and seal with room temperature vulcanizer:
https://usercontent1.hubstatic.com/13569880_f1024.jpg
Or this...
https://www.amazon.com/Universal-Cleaner-Smog-Vent-Fitting/dp/B01KW11JLK
I don't like the idea of no vacuum on the high side...
The Convert
1,487
1,053
Or this...
A nut is a big no no. Don't use any sealants or fasteners that could get ingested. Mine is a round plate that fits the recess in the end of the filter and an aluminum tube slide through a hole in the center, welded to the disk, and a flare put on the inside tube so it sandwiches the rubber of the filter between the flare and the disk.
camberadam
257
106
Baltimore
Tasmin Green e92
Mine is exactly the same as well.
Reactions: The Convert
