Well, 400wtq at 2500rpm. The GC2.0 certainly can spool. Looks like @V8bait was purposely limiting boost/load until 3750rpm too where he allowed the turbos to build a full 27.5psi and hit 560wtq.
I wonder what the limit was. Trans? Fuel? Time?
They were having traction issues (dynos in 5th fyi but 4th is equally impressive), so I brought in boost progressively and down low I was only targeting like 15psi. This was the first (and only!) revision and probably second or third run over 5,000rpm, higher we revved more it picked up. Boost should be about 15psi at early spool, then 20 ramping to like 26 or 27 up top. Timing was real conservative and fuel was very rich (fancy new lpfp pressure regulator is set a little high lol).
Basically, it was 4am due to daylight savings change, the first log showed everything working with zero timing corrections just too rich, so in the spirit of TX2K we sent it. I mean if it's too rich the best fix is add more boost (don't quote me on that). For a single revision it did awesome and I had a lot of faith in the work everyone had done and the parts on the car. 660whp STD not bad, I hope Robert posts the others.
