PR Coil leads
I've tested three sets now and they all are around .7 the only thing we have in common is we all got it at the time of original release.
Vdkk
34
24
335 e92
If I need a PR coil pack in a pinch can I find one at a local parts store? I know they are GM coils, I'd assume I could run a substitute for a couple miles to make it home?
I brought 2 spares and keep one in the trunk or keep a couple of stock ones and baby it home
Wont hurt anything
Twinz
23
Cape Town, South Africa
335i RWD
I just tested mine and they read 0.7
Purchased June 2017. I think those were the first released PR coils/wires. I have also been battling timing corrections/flatlining.
So what now. Buy the latest wires?? This sucks.
1,634
.7/.028 = 25. That’s quite a difference is resistance between the old coils and the new ones. Did PR chime in yet? Is it the case that the PR “replacement wire” set will be 0.028 ohms resistance? Do we know what’s the difference between the two, such as metal composition, etc.?
Reactions: Twinz
BOosted 335i
315
104
New Jersey
E90 BMW 335i
what i dont like about the newer set boots is the thicker top part where you push down on,now my coil packs sit closer to my top mount single turbo.I am not liking that.
Do what we done and make your own or get someone to make them for you
Resistance is only 0.019
We use the vtt rocker cover as it allows airflow around the leads
We also use hose pliers to take them on and off to make it easier.
BOosted 335i
315
104
New Jersey
E90 BMW 335i
BOosted 335i
315
104
New Jersey
E90 BMW 335i
Actually that pictures is the 1st gen boot from PR which i had no issue.i bought the 2nd Gen PR boot coils which are thicker at the top which cause the whole Kit to sit angled closer to my top mount turbo
Reactions: martymil
V8bait
505
785
Texas
Old old version the manufacturer didn't come through to spec on wires, so they got revised internally. Wasn't an issue they were still good wires just not where they should have been, they were similar to MSD wires when superior to Accel and MSD was the target. New-old version fixed that (second batch of wires onwards). Going too low in resistance isn't a huge benefit since the plugs have resistors but go too low and you can get RF interference, things like jb4 BT connect kits freak out for no discernible performance advantage as these coils are already powerful. If you want to bottom out resistance you should check into solid copper core plugs too.
Biggest issue with the old style boot was that some people had virtually no issues and appreciated the low profile, others would destroy them repeatedly, so the design was revised to improve fit, installation, and removal.
If the coils are too close to the turbo, you can pick up the N55 brackets and wires pretty cheap from PR, just message him about your fitment concern with the new wires and maybe he can help you out, he's pretty good about that kind of thing if you're honest with him.
Found an image comparing the cores of first (bottom), revised, and accel which is superior to msd-
if your not getting major timing corrections or drops don't bother, if you are measure the resistance on the lead with a cheap multimeter and your spark plug gap and resistance.
Everytime you change spark plugs you should check the resistance of wires and gap your spark plug to suit your boost and power level.
Reactions: Rcboosted2007
sch4400
18
so last batch... newest version is everything is fine ? no concern about that?
