https://www.n54tech.com/forums/showthread.php?t=38024 have you looked at this thread? I'm planning on something similar, I already have the 335d "suction hood" and have noticed a significant decrease in IATs, haven't done any specific heat shielding for the filters yet though. My plan is to do the heat shielding and then eventually use some of the HARD Motorsports ducting/piping to put even more flow over there, but I agree with the general sentiment that those of us with outside inlets just won't see temps close to the same as before unfortunately. Itll only get so good unless someone does some serious development for a cold air intake for hotside inlets, which I'm not holding my breath on.Yes I understand end temp will not change much if you place those specific variables in a test tube but that isnt how the world works. I just am not looking to beat a dead horse argument. But here goes nothing since you directly asked me. I understand that if the air was sitting in the turbo and fmic for a period of time long enough that all heat transfers "which it isnt" but say it does . You still are not taking into acount that you lose psi as your fmic cools ,yes I know the turbos will then compensate with more boost since boost is measured after the fmic but you are pushing the turbos further out of efficiency range if they are stock. You are also decreasing their efficiency by having less dense air enter the turbo to begin with. That's why people run volute injection and pre turbo injection on so many platforms ,ESP when turbo life doesnt matter. Why do you think BMW ran cai from factory. Yea time and time again it's been proven flow is greater than temp when comes to making power. 2 things though, that doesnt mean temp loses affect it just isnt as big and also when temp can alter flow by increasing efficiency of turbo then yes it will . As much as meth will help iat it wont help lower shaft speed. I have an ade 650 and my temps are within 10 degrees of ambient during normal driving they drop to close to ambient as soon as I go wot but In traffic I heat soak badly ,that is my honest main concern but all the above is just a benefit.
