New Member with A Dream
Ekarras
Hi,
I have joined this group to gain as much advice, tips and insight for a major Swap project I intend on commencing in a couple of weeks.
I have a 1998 RHD Z3 1.9l and 5spd Manual which I will be swapping in a 2010 E93 N55 6sp auto with all the looms being swapped into the Z3 from the E92.
I have some programming concerns due to the E30 Subframe and E36 Front end and those limitations on Braking systems and Differential talking to DSC and DME. Please chime in if you have done anything similar or have any advice or tips.
Reactions: AzNdevil
AzNdevil
604
290
Hong Kong
go google on how people do MK60e5 and MK60 ABS retrofits
e9x runs mk60e5 which is a newer variant of the e46 m3 dsc system and lots of people retrofit them as standalone abs systems into cars so theres a lot of info out there
hardware wise, you will need the dsc module with solenoid/pump, yaw sensor, szl (steering angle sensor + stalks), wheel speed sensors (iirc e36 ones might work), wheel bearings with the abs magnetic ring (iirc e36 has this but since z3 uses components from e30 in the rear, i am not sure), some way of turning dsc off (eg. button box or shorting wires that go to the jbbf)
heres a pinout of the dsc for reference
A65a Dynamic stability control (DSC)​
Plug connector overview​
NumberX-pin, colourDescription
X1830347-pin, naturalComponent connector Dynamic stability control (DSC)
Pin assignments at plug connector X18303​
PinTypeDescription /Signal typeConnection /Measuring notes
1ESupply, terminal 30Fuse F65
2--Not used
3ESignal, brake fluid levelBrake fluid level switch
4EBrake light switch signalBrake light switch
5ASignal Brake pad wear sensor, front leftBrake pad wear sensor, front left
6--Not used
7--Not used
8ASignal, processed wheel speed, rear rightConnector X10186 (rear right wheel speed)
9ESignal Brake pad wear sensor, front leftBrake pad wear sensor, front left
10--Not used
11E/ASignal F-CAN highCAN-bus connector
12ASignal, processed wheel speed, front rightConnector X10184 (front right wheel speed)
13--Not used
14ASignal, processed wheel speed, front leftConnector X10183 (front left wheel speed)
15E/ASignal PT-CAN lowCAN-bus connector
16MGroundGround point
17ESignal, terminal 30GFuse F20
18--Not used
19--Not used
20--Not used
21ESignal Brake pad wear sensor, rear rightBrake pad wear sensor, rear right
22--Not used
23--Not used
24--Not used
25AConditioned wheel speed signalCar access system
26E/ASignal F-CAN lowCAN-bus connector
27MGround DSC sensorDSC sensor
28--Not used
29EWake-up signal, terminal 15Connector, terminal 15 wake-up
30E/ASignal PT-CAN highCAN-bus connector
31--Not used
32ESupply, terminal 30Fuse F31
33ESignal, front right wheel speedFront right wheel speed sensor
34ESignal, front right wheel speedFront right wheel speed sensor
35--Not used
36ESignal, rear left wheel speedRear left wheel speed sensor
37ESignal, rear left wheel speedRear left wheel speed sensor
38ESignal Handbrake warning switchHandbrake warning switch
39ASupply DSC sensorDSC sensor
40ASignal Brake pad wear sensor, rear rightBrake pad wear sensor, rear right
41--Not used
42ESignal, rear right wheel speedRear right wheel speed sensor
43ESignal, rear right wheel speedRear right wheel speed sensor
44--Not used
45ESignal, front left wheel speedFront left wheel speed sensor
46ESignal, front left wheel speedFront left wheel speed sensor
47MGroundGround point
Ekarras
2--Not used
6--Not used
7--Not used
10--Not used
13--Not used
18--Not used
19--Not used
20--Not used
22--Not used
23--Not used
24--Not used
28--Not used
31--Not used
35--Not used
41--Not used
44--Not used
Thank you I will look into this, I appreciate the tip and info.
