At least 75 wheel in limp mode.Woudl you happen to know what is the most power I can get from stock turbos and pump gas?
Currently we have the 4th quickest 1/4 mile N54 in the world that ran a Shotgun to get there, I believe his tuner made 700+WHP on a single barrel on its own, before switching to a double barrel. Our product has been running on vehicles for 5+ years, with well-documented results, hundreds of kits sold, records broken and rebroken. If there is to be a competition it would seem to lie on the side of competitors releasing a new product to try to match the performance we have already proven. We look forward to what they can demonstrate as far as fueling capacity DI only, but the burden of proof lies on them.
Chris
My experience mostly in endurance road racing, Rob, is that one pushes one engineering envelope to another. Don't believe that by removing one problem with Design A one doesn't then realize another problem in Design B. At least for me, that's is contrary to a lot of performance development experience I've had, at the outer edge of abuse (which is where many of the failure stories originate). That said, I like what I think I see going on in this design ... but that's about as speculative as Mueller's burden of innocence argument .
No point in speculating and comparing to other solutions at this point: we know that just devolves into more useless mud slinging in which no one here benefits. Gotta wait and see.
The other part with this platform - is that testing/announcement to availability is rarely weeks, sometimes months, and OFTEN 1+ years. Gotta let the process work its way through. And then ... and I've seen this on this platform now a few times ... the cinderella arrives, but in reality it has to go through its larger real-life revisions. Flexfuel is about the only "new tech" solution I've experienced that was unapologetic out of the box.
The piezoelectric injectors aren’t the issue. They are like 3300cc injectors. The problem has always been having HPFP capable of fueling the injectors.
Injection window is the big limiter to the stock di setup. At some point, that window closes and the only way to inject more fuel without fully wetting the cylinder walls comes by way of pi.The piezoelectric injectors aren’t the issue. They are like 3300cc injectors. The problem has always been having HPFP capable of fueling the injectors.
While not everyone agrees with this portion of your statement, personally I do. The money you end up spending on piezo injectors and high pressure pumps and other upgrades over the lifespan of your vehicle will indeed equal a standalone and some fueling. The problem is that is not an immediately realized expense, there is a lot of custom work involved in doing a proper PI conversion and tuning a standalone to drive like the factory DME would be an expensive task requiring much more time than people likely realize.
If you want a refined experience, standalone most likely is not your best option...Nor is this platform. But I hear you, dumping DI may in fact be in the cards for me one day if I could obtain an N52 head, properly machined.
Why does everyone jump on a bandwagon without knowing anything about it?
Seemed to me that simplicity vs power option would be the S55 setup that was being played with. No special parts to replace/break and readily available.
It's just the tuning side that was a hold up IIRC.
When everyone seems to be wanting more power, the latest and greatest ... try future proofing your setup. Save money in the long run *to buy something actually fast).
I agree with you about everyone jumping on the bandwagon. Alot of unknowns with this, and no test data, flow numbers or lifecycle testing presented. I find it funny how venders on here claim " we have X many people running our product " . That is not testing. I could drive like a grandma for 3 years on one product and claim it lasted x amount of time, yet keep it at a high sustained rpm where the overdriven pump will be stressed and it will last a very short time. This is why you see a year or so later things failing. As an engineer it amazes me how this gets by time and time again on this platform. I hope that this isn't the case with this product and it has the data to back it.
I'm probably speaking out of line here, but I can say the way this has occurred is not the way it was intended. Apparently someone posted on Instagram they were selling this product without actually having the product in their possession or even the authorization to do so. And by that I mean, once the company found out the post was deleted immediately.
To prevent confusion as to who is actually behind the product they made their own post and here we are. If you are someone who wants X number of confirmations and more data, that is perfect because more testing is exactly what they were trying to do. Unfortunately that process has been sped up for reasons outside of their control because of what appears to be third party leakage.
Yup!Shitfire Race strikes again LOL
As an engineer, you are likely aware of the cost of testing. It's a double-edged sword: a more likely reliable product released later at a higher cost. The market pushes toward low-cost solutions. Let's be straight up - they push for it unapologetically. Vendors test enough that they believe they have a working product. As guys that build things, we have the proclivity to believe in our limited test experience ("ok it's good enough"), that it will extrapolate to a more general experience (yet most often incurs "ah ha" moments). We frequently repeat inflicting hope in our new creations, in spite of having the experience of knowing it is not true. And the social media world is a brutal place to watch that play out.As an engineer it amazes me how this gets by time and time again on this platform.
