If it were the case that, no matter what, ODing the pump wouldnt allow better flow due to the inlet then would the shotgun setups not work also? That's all I'm getting at here.There is nothing you can do to increase flow through the stock pump inlet, its that restrictive no matter how big your lpfp system is unless they modified the pump internal passages in some way.
But lets wait for the details.
Thats why people were so secretive about the porsche pumps.
I believe this is the pump they are using, and it is huge, so if it turns out to be working then no more fuel problems i'm sure.
it is funny cause some people knew for a very long time about these pums....
Not sure why BB focused the article on the porsche pump, the other M18 solution is the front runner and will have some pretty cool options to support very high WHP DI only.
I'm unconvinced that's the ultimate barrier. For some there is value to running one fueling system, not two. If that was not the case, I'd have a BMP on the shelf right now. I have others asking about when DI solutions are showing up as they prefer not to run both PI and DI.But will whatever solution that comes out be cost competitive enough to displace PI? I think that is the ultimate barrier.
Crazy, I remember talking with Steve at Fuel-It (before he became Fuel-It) about adapting in that Porsche HPFP setup. He seemed pretty hot and heavy on it, so I'd be willing to bet there was some snag keeping it from becoming a reality. Ultimately would be very nice to just have some very capable HPFP, off the shelf with no extra wear item like do hickeys, to just slap on and call it a day.
Rob
I agree it's not the ultimate barrier, but it is still certainly an expensive endeavor to get PI up and running properly - especially since most tuners will charge extra when going from a standard tune to adding Pi since so much more needs to be changed.I'm unconvinced that's the ultimate barrier. For some there is value to running one fueling system, not two. If that was not the case, I'd have a BMP on the shelf right now. I have others asking about when DI solutions are showing up as they prefer not to run both PI and DI.
It's not crazy, Rob, you're just getting old ...Crazy, I remember....
Rob
I agree 100% DI only would be my preferred method as well. Let the DME do it's J O B. I would pay more not to ever have to deal with PI. Which in turn means a slightly less expensive aftermarket intake manifold and a simpler fuel system over all.
lol ... I'll take that as a compliment.Yeah, you two are great examples of the 'typical' N54 owner and their $5K car 700+ whp #sendit plans .
PI also keeps the intake tract and valves clean which is a big bonus.Unfortunately, PI is 'working' and because of it's early and affordable enough price, I think to get the masses to shift to DI only, the solution will have to cost the same or even a bit less.
That is insane. And, that owners of Flex Fuel tend to espouse how great it is. That said, I would not be shy about harvesting N54 folks from FB that seem like a good forum fitI think @jyamona has stated that Flex Fuel hasn't sold as well as hoped - which is INSANE - it's FREAKING AMAZING. But hell, you got kids on FB that said they fill up their car with 93 while running an E60 map.
Maybe flex fuel hasn’t sold as well because it hasn’t made it to the e series n55 yet kind of kidding but kind of not.
