N54 Syvecs is dead
Flinchy
49
15
PI sadly will never be controlled directly by the stock DME because the MSD81 just doesn't have the mosfets / hardware to drive the injectors. That doesn't mean a better PI controller / intermediate box could not be built with DME integration, giving the same end result :)
As for the other 3 items, I don't see why they would not be possible.
I thought that's all anyone really wants? Not directly driving the injectors, but.. the DME controlling the controller I guess? So it can be actively aware one way or another as to PI Flowing.
Levanime
Supporting Vendor
Nov 5, 2016
13
NorCal
sorry for noob question,
but i was always wondering, why cant PI controller monitor DI signal, and cut the PI flow if it sees a cut on DI accordingly? i mean per cylinder
whats the technical problem with it?
Kenjermen
78
75
N las vegas NV
So the bases behind the Syvecs was to be a standalone, not a piggy back system. If you want something like this to be a piggy back system get a Haltech from AD-E which he sells the wiring harness as well so it's just plug and play like the jb4. I have this on my car and it's awesome I stack it with a mhd/wedge tune.
Flinchy
49
15
800 on race gas? any more info on that run?
Don't think there's been a run on the system.. more the fact race gas needs 30-40% less flow than E85 so that translates pretty directly to power capacity.
Whether the engine can take the added heat well compared to E85 though...
Jake@MHD
Nov 7, 2016
1,612
2,077
Philly
Because they wouldn't be spraying at the same time, due to DI injection window and PI needing more time open due to less pressure and how it pools fuel up on the valve etc.
Reactions: Sshec152
Terry@BMS
Jan 23, 2017
464
380
Cutting power to the coils during a misfire or imposing a 3000rpm rev limiter sounds like the best option at this point. I've been working on OBDII mode6 data lately for an emissions legal project. I suspect we can monitor the internal misfire counter via mode6 and then trigger the rev limiter before the car actually triggers a misfire.
Reactions: Levanime
4,342
Where would something like that fit into your to-do list priority?
Terry@BMS
Jan 23, 2017
464
380
With N54 development I've been knee deep in virtual flex fuel sensor logic, and user adjustable PWM meth control, but when those are off my plate I see that as the next big thing to work on.
Omar@VaderSolutions
Premium Vendor
Oct 19, 2016
535
409
NY & AZ
vadersolution.com
N54 135i & N54 335i
Question.....with all these new cars being released ... how busy is the n54 keeping you at this point ? Are you still trying to "develope" new things for this platform or have you moved onto other things ? Obviously I see you trying to improve the jb4
Terry@BMS
Jan 23, 2017
464
380
In any given week I spend a few hours with each platform. Some features like the new PWM meth implementation happen to apply across all platforms which is always nice. Other things I work on are say N54 or N55 specific. I keep a full plate and enjoy it that way. :)
Jason who handles a lot of our hard part development is hard at work too... Teaser shots of our upcoming stealth F10 water/meth tank I approved to move forward today.
4,342
The concept of a stealth tank is sweet, since I don't know the f10 trunk area, where does this fit exactly? Any hope for an E93 stealth tank? :)
Terry@BMS
Jan 23, 2017
464
380
Yes we have to project around 200 tank sales within a few month period to make it practical to produce.
4,342
I can only promise you one so I may be on my own. Is there another material which could be fabricated to fit in those spaces which is methanol tolerant? Obviously molds are not possible for a one off situation.
