n54 single turbo drag build
135iTX
115
70
2009 135i
Your car being stripped. Probably bitter you did this on stock turbos lol
135iTX
115
70
2009 135i
No idea, but there's a thread over on bummerboost calling your record a "record"
Silentkiller335i
116
179
Tony said your car would never run 9s on this build setup.
He is still wrong,
Reason I switched back to twins was to take this record, after these nitrous passes , these little stock turbos are coming off and my new single turbo goes on. Even bigger then my last. This is just the beginning with my car.
Reactions: 335is02 and Torgus
Aaron
544
201
Colorado
Silver 2013 335is 6MT
You haven't run a 9 yet? In fact the way I see it your still 3/4 of a second away, which isn't exactly a gap that 50hp is going to solve.
Silentkiller335i
116
179
Car has been stock turbo did you not read? Who ever said I’m only spraying a 50shot? I have up to a 150 shot. Just sit back and wait for the results. I’m not really trying to run a 9 on stock turbos. That wasn’t the goal. If it happens great. 9’s is still the goal on the single turbo setup which goes back to what tony said I can’t do.
Silentkiller335i
116
179
Little update,
  • Love
Silentkiller335i
116
179
Great run. Do have any datalogs of these runs that we can look at? What are the size of the tyres that you are running at the drags?
Nope. I always try to data log my runs but I seriously have so much to do at the starting line and before I take off it’s stupid lol. Tire size is 28x10.5 et drags
Coupes66
BMW 335i N54
Yes, I know what you are saying. I have forgotten to start the datalog a few times because I am thinking of staging after the burnout. With the 28 x 10.5 tyres, I would imagine you would be around 6,000rpm in 4th gear going across the line.
Silentkiller335i
116
179
DME say hello to your replacement will be the first n54 in the states to run this ecu.no more DME restrictions and no more DI,pre turbo 02’s . End result is a reliable and consistent n54 on race day.
  • Anti-lag and launch
  • E-Throttle
  • Knock control
  • Built-in wideband
  • Shift-cut and internal loggings
  • Flexfuel
  • CAN bus
  • Traction control
  • VANOS / VVTi, variable valve timing
  • 2 knock sensor inputs
  • 8 built-in EGT (in harness)
  • 8 injector output (high/low impedance)
  • 8 ignition outputs
  • 9 extra (GND) outputs
  • 2 extra (+12V) outputs
  • 2 extra outputs for E-Throttle
  • 8 extra analog inputs
  • 4 extra digital/VR inputs
  • Bluetooth
MoreBoost
361
143
Great trap speed by the OP and great results in total. I'd always be concerned with nitrous doing a lot of damage though. It's such an archaic method.
I find it crazy that 13 years down the road, N54s typically aren't trapping over 140mph. My personal car has nearly done 130mph but suffered from the dual mass flywheel triggering misfire detection about 2/3rds of the way down the track.
