People keep saying the cowel is a heat trap like BMW didn’t do aerodynamic testing on these cars...it is not a heat trap. It closes off the top of the bay and forces the air in the bay to exit on the underside of the car. When you remove your cowel, you upset that flow, create more turbulence/drag, and likely cause higher under hood temps.
That all said, I’m also a perpetrator as I have the M3 cowel that doesn’t seal properly against the non M hood, but that lack of sealing surface is on the list of items to fix.
Heat rises. It's a heat trap. With the cowl off you can see the heat haze coming from the bonnet. Especially when you aren't moving and there's no vacuum to draw the heat out.
Surely you aren't going to argue this.
