N54 Dragy Times
Status
Not open for further replies.
dyezak
1,767
1,518
Plano TX
335is
Alright @Terry@BMS it looks like the things have been proven...I guess this will be one of my next purchases after I get done with the single turbo conversion.
Rcboosted2007
902
90
Parts unknown
07 335i
I would wait till after. I bought one before stage 3 mmp and draggy showed gains of 0.4 seconds lol. after turbos, PI ETC supporting mods. Heartbreaking
1,286
781
Embarrased to post this because of the ET, but that's on me, not the Dragy, lol. Just showing the accuracy. My Dragy had fallen under a seat and I couldn't find it, but it connected, so I knew it was in the car. It did tell me low satellites so accuracy may have been somewhat better with line of sight. Only got this one pass in before the outlet hose popped off the next pass just past the 1/8 mile. For some reason the second pass dragy didn't record, I may have accidentally closed the app, but I cut a great 2.3 60ft and it did go 96 in the 1/8 on it.
If I can just find a decent road around here to test with, I won't have to go to the track constantly and drop 20 bucks to make 1 pass if a hose pops off, lol. It's funny looking at MellowYellows's reports with a .05% slope, compared to the .32% I have and I'm on a drag strip! Anyways, I'm extremely satisfied with the Dragy's accuracy, just not my driving. Just wish the Android app would get updated with the same features as the IOS.
Mightbaal
76
12
2008 335xi E90
FBO+INLETS+E85 BEF 22 psi mid range 17 redline stock turbos. Car loaded with 2 beefy car seats... a sub enclosure amp tools and tons of paintball gear and I am 220 lbs car is a 2008 BMW 335xi (awd)... I'll get this down to mid 11s this was just one run...
Reactions: TX_335is
Mightbaal
76
12
2008 335xi E90
Are you guys launching in 1st or 2nd?
I am launching in 1st as you can see the 0-60 shift dip in acceleration. However I am AWD with aggressive extreme performance summer tires squared 245 all around. Pirrelli P Zero Nero GT. They sometimes slip alittle if I brake boost alittle high off the line but it's very rare depends on the type of road really. Mostly it pulls off the line like a raped ape with 5 psi spooled up at launch. If I spool to much my transmission will skip into 2nd gear for some reason. Every once in a while I'll get a minor slip on the 1-2 shift.
Mellow Yellow
53
37
Hà I love that road. 3 lanes accross out by a slow airport with no traffic and freshly paved
Mightbaal
76
12
2008 335xi E90
Flush the trans fluid, give it a go in M mode so it doesn’t slip its way into 2nd gear on its own
Still jumps to 2nd even in Manual mode... I had a BEF that did something weird once along time ago thought 2nd gear was 100% dead it would slip out of 2nd all the time and go to 3rd and the most painful part was on the 1-2 shift it would sometimes slam back into 1st overreving the engine and painfully feel the tires slip. Did a fluid flush sleeves mechtronics seals etc at that time (60k) didn't help reflashed to stock then back to the BEF never had that problem again. Not sure what that was about.
LessIsMore
56
22
09 535i
Full weight DD loaded 535i sport, mods in sig.
Temps were in the 80s, bumpy back road. Spun 1st and 2nd gears, and it was a bit uphill. As it sits, I think I can crack 120 mph in 1/4 with a bit cooler weather.
Starting in first gear and short shifting to 2nd still works better than 2nd gear launches, which bogs badly every time.
suspenceful
10 Second Club
Aug 1, 2017
559
592
75
2015 M3, 2008 135i, 2009 335i
Thanks to BMS for hooking it up with this Dragy! My 6MT 135i with 6266 @ 27psi with a full tank of gas and a passenger. I'm pleased with the results, but know there's a lot of room for improvement. Gonna try again by myself with 1/8 tank and see if I can improve the shift bog (see yellow line).
Reactions: TX_335is
Status
