Motiv Flex Fuel Installation Guide
Jake@MHD
Nov 7, 2016
1,615
2,083
Philly
Mine does not have anything in this slot. Is this and issue?
Update - All up and running. Does not seem to have impacted.
Most euro cars will not have the wire there. You are good.
I signed up Friday. As of this morning, MHD on my phone says v1.66 (supposedly 1.7 is the beta?). There are no updates in the play store. I've been on MHD for about 18 months. Signup says I'm a tester and play store says I'm a beta tester. Any ideas?
Uninstall your current version then check the play store again
3,642
Yup. Did that twice. No luck. Says v1.66, but says I'm in beta program. Rebooted phone on second install for giggles. No luck.
@jyamona .
Can a fuel-it flex fuel analyser be wired directly into the dme to read E content with the new software
How if so ?
Which analyser if so ?
I just want to be able to see E content in the logs if possible.
4,348
@jyamona .
How if so ?
Any reason you don't just use the built in capability?
Jake@MHD
Nov 7, 2016
1,615
2,083
Philly
Exactly. Seems like something always popping up that I want to power. I believe this is called Term 15 (powers on with ignition only, engine not started)
Be careful how many things you power there off a single orange wire, they supply the coils and injectors.
NoGuru
1,213
597
Just North of Detroit
BMW 335is
I'm stumped on connecting the fuel line. Is it supposed to be a direct fit to the stock line?
I removed the stock line from the where it runs up into the engine bay and connects to a vapor filter.
E90TommyB
37
Indiana
2007 E90 335i
Im confused on how to install the power wire from the flex fuel box. Do i use the posi tab to tap into the orange power wire directly?
Reactions: Abacus38
NoGuru
1,213
597
BMW 335is
Yep, thank you.
So this is a little embarrassing but I will share so no one else does this. There is a vacuum line that runs next to the fuel line. This is what I originally pulled and was confused about how it connects since it never could :) Anyway the vacuum line is the one towards the outside of the car.
For the power wire, use the posi to tap the power wire that is in the DME box all the way to the front. There is only two wire connected there.
3,642
Thanks for post this. No reason to be embarrassed - we all do something the first time.
Reactions: NoGuru
1,630
Yep, thank you.
I’ve done stupid things too. I think I’ll start a “Doh!” thread. :eek:
baturbo
15
Melbourne
2006 E92 335i RHD
Yep, thank you.
I struggled to work out how to install the sensor and hose until I found that post and looked up the part on realoem. It would be nice if motiv had even a basic guide to point novices like me in the right direction
