Is their anyway I can get my licenses without using the Android!
I login and I got this frame !
I can manually generate you voucher codes for them if need be, but will try to figure out the Android issue first. Can you please turn off all developer options on Android and try again. Also take a video of what you are doing if possible.
Thank you.
You should just be logging in using google with whatever email address you used for your initial mhd purchase.
You do not manually go to the URL in the browser. Click the login button in app and make sure to choose Chrome if asks what browser to use. Also make sure developer options are turned off in your android settings, and report back. Post a video if still facing the issue
mI can manually generate you voucher codes for them if need be, but will try to figure out the Android issue first. Can you please turn off all developer options on Android and try again. Also take a video of what you are doing if possible.
Thank you.
How can I send a video! I got only my pictures!I can manually generate you voucher codes for them if need be, but will try to figure out the Android issue first. Can you please turn off all developer options on Android and try again. Also take a video of what you are doing if possible.
Thank you.
I appreciate if you can send me a voucher with my licenses for my ios apple 6 ! Im destroying that piece of Android crap that I have!!You just need to do one step at a time. You're only showing the end result and not describing how you're doing it.
Open the Android mhd app. Click the hamburger button in the top left. Take a photo and post it here .
Let's start with that
Ah, I'm not affiliated with MHD, so I can only try to guide you through it. Besides, if there's actually a problem then it would be better to identify and solve it so others don't have the same issue.
I tried signing in with google , and got and error!Like I said before, that is a last resort. We must troubleshoot this first. Thanks
