Datalog Measuring Oil Level through MHD
893
So,
I have been monitoring the oil level and pressure in my e90. Had a highway drive for 40 mins. Level was hovering between 45-73mm depending on throttle pedal force. If I pressed the throttle fast the level shoots up to 73. If slow press then it slowly goes up. When braking or taking a ramp that leads left the oil level dropped to a low 11mm. This happens only on a left turn or braking which im not surprised considering the pan is tilted. Tells me that the pans should have came with baffles or a stronger oil pump and larger pickup tube (a reference to the S55s oil pump, pickup, and pan system).
I haven't watched my oil level a ton yet, but so far I've only seen it get down into the 30's if I brake really hard.
