M3 KOMBI Virginizing (DIY!!)
R.G.
668
328
Henderson, NV
E92 335, F10 M5
The fact that you're way off topic and forcing the conversation into a different direction (i.e. derailing the conversation). If you want to start a "why should i put an m3 KOMBI in my car thread" sounds like you have an ax to grind with that topic.
Nah, just the hush hush type vibe of the thread with the ignoring members relevant questions kind of rubbed me the wrong way is all. I wasn't aware of any advantage other than the white + rpm lighting (obviously some nefarious mil. tinkering as well) but it sounds like you believe there is. Gives me something to look in to I suppose lol.
LMB335is
301
189
FOB FL
13 335is
You don't need to believe there is because there is. When you're in the middle of a full on M3 GWS, TCU flash, DSC, KOMBI retrofit featuring MDrive and MDM you'll understand.
NoQuarter
1,662
1,066
Indiana, USA
Z4 35is, 535xi, X5 35i
Just because a post got missed doesn't imply some sort of conspiracy or being ignored on purpose.
R.G.
668
328
Henderson, NV
E92 335, F10 M5
Could someone please just post the fucking reason to does this retrofit?!? Ffs.
M3 cluster + dynamic RPM lights + DCT shift lights probs cool.
M drive mode with EU comp version of DSC software needs new column + coding, possible cluster is needed but never heard that was the case
I'm still guessing lights
Reactions: The Convert
R.G.
668
328
Henderson, NV
E92 335, F10 M5
I 100% agree. I honestly just thought there was a possibility someone would have thought that changing one module could change anything without changing ALL the modules since they are programmed to work together. I don't know if someone is a pro or just tinkering hence why I asked what the purpose was. Best case someone would waste their time, worst case someone would F their car up. For the MAJORITY this is a "lights" mod. The freaking pretentiousness in this thread LOL
LMB335is
301
189
FOB FL
13 335is
There's a couple different reasons. If you want to retrofit a M3 cluster, whether for looks or whatever, you need to erase the VIN and the mileage from the Eeprom that stores it . It's a chip that you can't overwrite with the usual methods of NCS, Tool32, or WinKFP. If the replacement cluster has lower mileage than the one it's replacing it will take the mileage stored in another module. If it's higher you'll get the tamper dot. You can't code it with the VIN mismatch, you get a tamper dot, and it causes other issues as well.
Same goes if you just need to replace a unit that's malfunctioned and needs to be replaced. If you buy any used unit it will need this done or you can spend $900-1000 for a new one from BMW.
LMB335is
301
189
FOB FL
13 335is
Shift lights won't work on a non M DCT car. Signal comes from the DME and our DMEs don't have that signal.
MDrive/MDM can be either US or EU software version. You only need to change two parameters to switch between the two. You definitely need a M3 DSC/ABS unit, a shitload of custom VO and parameter coding. and a M3 SZL for $2MA. If you want to see this on your cluster you'll need the M3 cluster as well.20180308_104627.jpg
dyezak
1,767
1,518
Plano TX
335is
There could be over 100 different reasons or purposes depending on the individual or their desires and needs. Had your factory KOMBI damaged and want a replacement, want the looks, have a built engine and need a higher red line, want to show MDM on your full conversion, want the lighting updates, want the look of the M interior, I can keep going for a while here. That's not the purpose of this thread because the want/need is so varied that it is its own discussion.
This was a simple discussion. Does anyone want a guide on how to do it? It's a yes or no question that some people can't answer because of their need to point out how much smarter they are than others and why they don't need to do this in the first place.
Whatever.
2,198
Seems like a lot of work but if I had a dct n54 I would do this. The gauges do look very nice. Or something to do if you have a 8200rpm rev limit...
2,267
813
To answer the OP, Yes I’d like to have a guide. I like to learn whether I need it myself or not I might be able to help someone else at some point.
R.G.
668
328
Henderson, NV
E92 335, F10 M5
Whatever.
The effort to keep the thread on purpose seems to be for not as no one will respond "no" to any guide being offered. Actually outlining some of the reasons why someone may need it (as tedious as that was to get the info) added a purpose to the thread.
Stokes
271
177
Houston, TX
2011 BMW 135i
@dyezak I was able to clear the mileage and vin, reset via ncsexpert (process ecu followed by execute), but it seemed to take the E82 configuration. Any thoughts to what to change to have it reset to default M3 config?
EDIT: Got it. Changed VO to say it was a M3, then repeated and now all is right.
Stokes
271
177
Houston, TX
2011 BMW 135i
A DIY for this would have saved me a lot of time. It's not difficult, but not having to second guess or search for something long forgotten would be greeeeeaaaattt.
