Bad choice for a comparison on the LS coils, assuming you used D585 coils. Those are commonly known to have problems at the dwell times you were testing them at. Try the other type of truck coil it's much better, I believe they are made by Metco. But even the standard LS 2/3/7/9 coils should do better in your test.
We tested the normal ones and they were less powerful. The issue you're talking about is when you dwell them too long and the smart coil triggers a protective spark, which is similar to advancing timing. This only happens at around 6ms, and yes it's a big problem... But only if you dwell them that long. Most LS builds will dwell them for around 4.5ms to avoid this. The 585 was the highest output LS tested.
In the .zip I posted there's some shots where we set the dwell to like 7ms and you can see the coil fire prematurely. Definitely shouldn't be called a "smart" coil lol.
Edit:
@Milan here is a scope of the issue at long dwell on D858, purple is dwell signal, it's at ~7ms, you'll see the coil discharge on its own just before the signal ends. Big spark though.
