How can you claim both install take the same time then ? One is plug and play, the other you need to go under the car and cut cooling hoses and stuff...You don't have to cut it, you can replace the whole cooling hose which makes it reversible or just buy a new cooling hose that you cut.
It's not irreversible and not permanent
I'm begining to doubt your objectivity...
Try to face the facts, Helix is a much more elegant and easier to install solution. Unless you are a VTT fanboy i see no reason to go with the single barrel.
