What problems are you facing that makes you not want to increase boost? 32years. Jarek is the guy from MGF who makes the engine maps. Engine stock or forged?Because its not that simple. How old are you? BTW who is Jarek?
what is the time 100-200 on this setting?Its not only about to increase boost. You are limited by fuel, octane, knock, compressor housing size and much more. 22.5 PSI on 100oct fuel at 10° timing advance is the limit what my tuner (not Jarek) consider as a safe limit for this setup. We are about to tune the car for WMI right now. And no, it does not have to do anything with OTS maps... i am on custom tune. Engine is stock. 11:1
F30, 320xi on MGF tune. Engine, turbo stockDont know yet. Will post some results later. How about you?What car do you own?
hi, how is the car doing? Are there any changes? Did you take measurements of 100-200?Hi sqwin, nice to see you around. I have read your comments on another forum, very informative. Yea, what Musa is doing there is just impressive. He is pushing the limits. As for IPOS... i was just a bit too fast with purchasing my Stage 2 Turbo. They have not been that well known a year ago.
Good job! Can I look at the log?Hi. WMI map finished. Car is running 230 load targets across the rpm's with decent timing of 12° max. Airflow is at 1.015kg/h which is round about 350hp at crank. Still have to do some 100-200 runs to verify the progress. I ll post all the results once done of course
By the way, what do the parameters look like on the map without WMI?Here is a log with multiple gears... started in 3rd ended in 5th. You see the issues with CP WMI Injection. Ignition is not stable due to uneven meth support. As we finished the WMI Map recently, i ll add a jug of Ethanol to mix my fuel and do another log. I expect the ignition variance to disappear. Will post more later.
BTW, Tuner said fuel and tune wise we are at an ~E20 Level of Power. AFR is at ~12 at WOT. Boost peak at this run was 23,6 PSI.
