Dyno Results - Single Turbo 6266 BMW 135i Makes RECORD Power?!
suspenceful
10 Second Club
Aug 1, 2017
559
592
75
2015 M3, 2008 135i, 2009 335i
I finally strapped my 135i onto the dyno this weekend and am thrilled with the results. I can't find a higher published power output from a PTE 6266 on an N54! Now I need to put my Draggy to use so I can see how I compare to some of you guys...
I did a handful of pulls at various power levels and attached the logs below. This should give everyone a good idea of what a properly set-up 6266 can do from low boost to high boost. You can find my complete modification list at the bottom. And yes, this is a JB4 car!
All pulls done in 4th gear (manual transmission). DynoJet with STD correction.
Watch the video with speedo & exhaust angles... plus lots of awesome turbo noises. I also explain a lot of stuff as I'm dynoing the car.
Shoutout to John @ Doc Race for providing an awesome single turbo kit and support. I can't wait for that intake manifold. Terry @ BMS for the log feedback and guidance. Ken @ WedgePerformance for a personalized backend flash and good communication. Steven @ BMP for the quality port injection kit. Tiago @ VRSF for an awesome intercooler and Robert @ Precision Raceworks for the fuel setup and ignition kit. This car wouldn't be the beast it is without you guys!
Let me know what you think!
2008 BMW 135i, stock motor with 90k. My complete modification list with product links (let me know if this isn't allowed for some reason).
SINGLE TURBO KIT
Doc Race Single Turbo Kit w/ 6266 ball-bearing turbo: https://docrace.com/collections/turbo-kits/products/bmw-335i-n54-n55-single-turbo-kit
*Save $100 on your kit by using discount code N54JAKE during checkout!*
TUNING
JB4 Tuner: http://www.burgertuning.com/jb4_pnp_BMW_performance_tuner.html
JB4 Wireless Connect Kit: http://www.burgertuning.com/bluetooth_jb4_connect_kit.html
Wedge Flash: https://www.facebook.com/WedgePerformance-1253879854659791/
MHD Flashing Cable: https://amzn.to/2qGKbl2
OTG USB Adapter: https://amzn.to/2qKvc9R
PERFORMANCE UPGRADES
Custom 3" turboback exhaust: https://www.facebook.com/LegendAutoLLC/
VRSF 7.5" Race Intercooler: http://www.vr-speed.com/vrsf-7-5-st...-kit-07-12-135i-335i-n54-n55-e82-e90-e92.html
VRSF Charge Pipe & TiAL BOV: http://www.vr-speed.com/vrsf-chargepipe-upgrade-07-13-bmw-135i-335i-n54-n55.html
Precision Raceworks Ignition Kit: http://www.precisionraceworks.com/index.php?route=product/product&product_id=82
Precision Raceworks Stage 3+ LPFP: http://www.precisionraceworks.com/index.php?route=product/product&product_id=71
Black Market Parts Port Injection Kit: http://www.bm-parts.com/index.php?route=product/product&product_id=188
JB4 Port Injection Controller: http://www.burgertuning.com/N54_secondary_fuel_line_adapter_fuel_Injectors_BMW.html
Oil Catch Can: https://amzn.to/2Hd1p0L
RB PCV: http://www.rbturbo.com/rbpcv
NGK 5992 Spark Plugs @ 0.022": https://amzn.to/2JWIf0A
3.5 Bar TMAP Sensor Kit: http://www.burgertuning.com/N54_JB4_upgrades.html
TRANSMISSION
SPEC Stage 3+ Clutch: https://amzn.to/2HbICCZ
MFactory Single-Mass Flywheel: https://www.n54tuning.com/mfactory-light-weight-flywheel.html
Race Transmission Mounts: https://www.ecstuning.com/b-uuc-parts/transmission-mount-bushings-race/tmrace~uuc/
BMW Performance Short Shift Kit: https://amzn.to/2JW5hVz
Teflon Shifter Bushings: https://www.ecstuning.com/b-ecs-parts/teflon-shifter-bushing-kit/2511-002~3/
Clutch Pedal Stop: https://amzn.to/2qJTfG5
Clutch Delay Valve Delete
JB4 No-lift-shift/2-step Relay: http://www.burgertuning.com/N54_JB4_upgrades.html
Redline D4 ATF Transmission Fluid: https://amzn.to/2JWbssH
Redline 75W90 Rear Differential Fluid: https://amzn.to/2J6pPt7
Get your N54 & Single Turbo BMW-inspired apparel now: https://bimmerstreet.com
Follow me on Instagram: https://instagram.com/jakespence
Subscribe to me on YouTube: https://youtube.com/jakespence135
  • Dyno 749whp (29psi).csv
  • Dyno 708whp (26psi).csv
  • Dyno 658whp (21psi).csv
  • Dyno 552whp (16psi).csv
  • Dyno 453whp (11psi).csv
suspenceful
10 Second Club
Aug 1, 2017
559
592
75
Supra guys made 800 whp on a 2JZ over 5 years ago on a 6266. Hondas commonly hit 700's out of 4 cylinders on a 6266.
As I replied on N54Tech, I was referring to just the N54 community. Sorry for the confusion.
1,563
Congrats on the results man! Happy for you. Hope the satisfaction is over how well the car is running vs any perceived records though, don't want you to end up popping another pringles can chasing numbers. :D
chadillac2000
233
255
NC
2008 BMW 135i
Sick buddy! Impressive to see what the car did on even low boost. 750WHP is getting after it though -- seemed to do it with ease. Gotta love a dyno session with no issues. I'm particularly impressed with that 658WHP/554WTQ spread at 21psi; probably what I'll end up settling on for daily use. Seems like it could do it all day long.
Any plans to turn anything up when the DocRace IM arrives? Or were you just looking for a safer way to implement the PI and bling up the bay?
Reactions: suspenceful
2,197
I assume they don't hit those with stock cams on either motor, and I would bet not stock blocks either.
The doc race or fabfactory intake manifold and high lift cams should get him to 800...or at least much closer I would think. He could also upgrade to a 3.5'' exhaust from his 3''. You would probably want it to delete the transition that mates to the stock exhaust. No reason to split just to go back to a single a foot later. To go on I would bet you could remake the downpipe off the turbo and get a 3.5'' to fit like the VM/ACF kit vs. the 3'' Docrace downpipe. So he would end up with a full 3.5'' exhaust all the way back. At this HP level a 3'' exhaust should start to become a restriction.
Throw on a built head and 800+ should be very doable. I would even bet 825 could be had. Assuming he is chasing that 800whp+ number that is.
suspenceful
10 Second Club
Aug 1, 2017
559
592
75
Thank you! I'm so happy with the way the car runs. I won't be chasing more power on this motor, I want it to last as long as I can possible make it. I usually drive it on the street at 24psi and have been changing the oil very frequently.
That's what I was thinking! The 21psi results impressed me the most, I had no idea it would be surpassing 650whp there. I was expecting 600whp at best.
I'll probably actually head back to the dyno and see how much power it adds by itself. Then I might drive it with even less boost so it makes the same power. I really bought it for the looks and to eliminate a potential leak surface on the intake side.
I assume they don't hit those with stock cams on either motor.
Yeah. The motor itself is completely stock, never opened. Stock intake manifold even.
I think if I leaned it out and added more timing, I could've done 775whp+ easily. It was really rich and the log was really safe. I already got rid of the exhaust split transition. Chopped the lower Doc Race downpipe and welded a 3" v-band so it's a single pipe the whole way. We'll see how quickly I get used to the power...
Abacus38
643
385
Tampa/Orlando, FL
2007 Ti Ag 335i
Nice numbers!!!!!!!! but don't get crazy with 60-130 times. You'll snap an axle if you're still on stock axles. Also that turbo still has about another 50-60whp in it at least I wouldn't push it since you're on the stock motor.
SlowE93
1,723
Just a plane ticket away !
E93
SINGLE TURBO KIT
TUNING
TRANSMISSION
I hate how clean your timing looks :mad:!!!!!!
dyezak
1,767
1,518
Plano TX
335is
SINGLE TURBO KIT
TUNING
TRANSMISSION
I’m a big fan of yours. Love your build. And budget bimmers. You guys remind me of my 4g63 days.
dyezak
1,767
1,518
Plano TX
335is
Lol! The 335 is kinda the modern day dsm. Great engine that can be made fast and the rest of the car is junk.
I went through 3 GSX's, 1 TSI AWD, and 1 EVO. I was hooked until I saw the 335i. It was a modern Supra in my eyes. Traded my EVO MR in for my first 335i back in 2009.
4,339
The 2G eclipse had some body style mojo going on, had to admit. There weren't a lot of budget cars being sold at the time which had such broad visual appeal.
dyezak
1,767
1,518
Plano TX
335is
Those are fantastic numbers Jake! Great work
So I haven't spent much time reviewing JB4 logs lately, but looking over Jake's logs for the 750hp pull shows a perfect pull. The 6266 carried boost all the way to redline which means there is 0 boost leak/psi loss in the intake track. The average ignition value is also 1.5 across the pull, shows he hasn't had any fueling problems at all. He was hitting 9.5deg of ignition advance which is really good at this boost level.
What this tells me is that mechanically this is a very healthy motor and the maintenance is top notch. It also tells me that at this boost level on a 6266 there isn't anything left on the table for a factory long block. You'd have to improve VE to see any gains which means digging into head porting, cams, etc.
But, looking at the WGDC there is room on the table for more boost.... I'm super impressed.
