DOC Race intake manifold group buy discussion
2,198
Are they going to supply a chargepipe?
I think they would have to, otherwise each person would have to have a shop fab one up. No reason to let all those companies make the money...and the customer would benefit obviously. Probably best for everyone and make it connect to a 3" up pipe. More sales for doc race.
Does anyone remember the n54 throttle body size? Probably not the best place to find gains, I was just curious.
134
81
2010 e90 335i
Yeah well I think it's ridiculous if they didn't supply one. And as far as I know any other forward facing manifold did not come with a charge pipe in the past. Someone had made the excuse that some fmics fit differently. Well there's only a certain amount of high quality fmics And I don't think they fit that much different. They can test fit each fmic which is rather easy. If youre worried about your $97 ebay fmic not fitting you deserve to pay to have a charge pipe made lol. Just my thoughts
Reactions: boostE92d
1,651
hugely agree. Let the end user modify the supplied pipe to fit their fmic. That's easy enough even bolt on shade tree wrenchers like myself can do it.
Yeah,I agree above.Adding a 3" charge pipe to cold side intercooler would be a great idea and sell.you don't have to waste time getting one made,plus the down time.think the manifold would sell better with it.
1,630
This may have been discussed before, but wouldn’t it be more desirable to have the PI ports on the intake manifold as close as possible to the intake valves? It would seem the distance between the DOC race manifold PI ports and the intake valves could create a fueling lag issue. Just wondering...
4,345
It would indeed be better to have one supplied. But there would definitely need to be a little work between the end of this chargepipe and whatever FMIC the customer has. This would probably be manageable however. This is the argument that Fab Factory made when they sold their manifolds.
1,651
No doubt the fabfactory manifold flows well and is a work of art, but I always felt that was just such a huge cop-out.
2,198
I mean anyone who buys this manifold is almost guaranteed to have a 3'' up pipe from their IC. Which would be the BMS or VRSF IC. I can't imagine you can get a 3'' up pipe from IC up to the manifold/engine bay in many locations. A small charge pipe with a 3'' silicone coupler should be fine and give some wiggle room. Or just guarantee it fits one or the other. It's more revenue for DR and significantly less hassle for the customer.
Unless you can make the CP yourself this means you have to pay whatever shop is fabbing it up to also install your IM. Which just adds cost and makes the entire process more complex.
We had up pipes made for fab factory manifolds for a while now, they are not cheap to make and very time consuming.
There's a single turbo/tft inlet style up pipe and a twin turbo for rb/vtt silicone style inlets up pipe.
Both are very different and pretty pricey because of the labour charge and the extreme tight radius
bends that cant be bent, they have to be made out of alloy donuts.
Lots of welding and pretty much has to be made on the car as its not one size fits all again.
Differences for example
Engine fan 650w or 850w slightly different
manual or auto
radiator factory or aftermarket
style of BOV or BPV
The Convert
1,487
1,053
The first picture looks like there is no intercooler? Second looks pretty nice.
This is the final incarnation of the pipe and the finished product what we made.
The IC is a work of art and absolutely expensive to make but it works
We sold around 16 of them without a single complaint but that's another thread
Just showing you guys that there is no room for error making these pipes.
They are both 3 inch up pipes with basically mm to spare all around.
There is basically no way to mass produce these.
Reactions: lamia2super
KevinC39
234
118
Ok maybe I missed it but what's the advantage to a forward facing intake manifold like this vs a stock style that enters in the middle?
35rwk in the midrange with absolutely no changes to the tune and around 20 rwk as well
when you optimise it for the manifold that's with the ff manifold
the doc race one should be the same or maybe better.
To answer a question someone sent me
These pipes fit both 1 and 3 series in style but
every car is slightly different.
Just because it fits one it might not fit the next
Each pipe is custom made to the individual setup
This is why no one mass produces these, it just wont work.
