dyezak
1,767
1,518
Plano TX
335is
dyezak
1,767
1,518
Plano TX
335is
Good to hear. How does it drive with the more aggressive ratio?
I really didn't notice it too much. Other than first gear goes away very quick.
The thing is I have less traction issues with the M3 LSD so the old 2.56 just lit up first gear. Now I have traction so it feels like it goes by the same haha. I also need to replace my VC as my current one cracked bad and I am way down on boost/power with that boost leak.
Reactions: Stokes
dyezak
1,767
1,518
Plano TX
335is
A high level summary of what I have learned through this process:
If you want to run Shiftlogic you need:
1. M3 GWS
2. M3 Console Trim
3. M3 8pin plug
4. M3 Shiftlogic button
5. M3 Diff/Axles/Driveshaft (3.15 gear) OR the upcoming* (@jyamona) MHD flash time option to keep your factory 2.56 diff
6. M3/GTS EKG Flash
If you want to add adjustable Launch Control you need:
1. Shiftlogic
2. M3 SZL (not needed on z435is, it has the correct SZL)
If you want MDrive you need:
1. Shiftlogic
2. Adjustable LC w/M3 MDrive SZL
3. M3 DSC
4. M1 DME Flash
Each of these steps takes progressively more effort on custom coding/flashing/etc. I am only missing the very last step (M1 DME Flash) to enable MDrive. I'll wait until I have my 6266 single on there and we will tune that single setup in as if it was an M1.
Stokes
279
183
Houston, TX
2011 BMW 135i
Oh yeah, open diff to LSD is amazing. :)
I ran some numbers based on a 265/35R18 tire... for street driving, you may not notice much. I'm worried about top end on the back straight at COTA. That means if I follow your lead with the 3.15, I'll just have to deal with running 7th out close to red line.
6000 6500 7000
1st373040334335
2nd604965537057
3rd826789729678
4th1058511493123100
5th127103138112148120
6th147119159129171139
7th177143191155206167
2.563.152.563.152.563.15
[TBODY] [/TBODY]
Reactions: boostE92d
dyezak
1,767
1,518
Plano TX
335is
Excellent work and perseverance Derek.
If you were in Australia, you would be sitting next to me right now ;)
I don't think I would have kept plugging along if it weren't for you. The firm stance that it will work gave me hope and reason to keep dumping time and money into the project.
Thank You sir.
dyezak
1,767
1,518
Plano TX
335is
600065007000
1st373040334335
2nd604965537057
3rd826789729678
4th1058511493123100
[TBODY] [/TBODY]
This setup will really come into its own with a built head and Ferra valvetrain that can run 8000rpm.
RSL
503
Excellent news! Now some vids/logs while we wait for a workaround on 2.56 please :)
@Stokes if Jake can do it for N54, not sure how much more difficult it will be for N55. Run HPDEs at COTA? I'm in Austin.
2,267
814
Awesome stuff @dyezak ! Congrats on making it as far as you have. Now we have the fun of tidying all of this up for those that want to go 'all the way' Open to suggestions on how we would do that? One step is to make the thread public but that shouldn't happen until the guide has all the info to prevent the inundation of various questions.
We should probably also wait for the test of the flash change and see if Jake and Terry are successful as well.
Bimaxtremeretro
78
78
11 ba$tards and counting
Thank You sir.
Been a real pleasure mate.
If terra is involved it's as good as done ;)
dyezak
1,767
1,518
Plano TX
335is
Guys, I want this section to remain private for a bit. I'll work on a first draft of a public post we can put out there for the masses in the next week or so. But you guys all contributed to this and I want you all to have the ability to put your $0.02 into the post AND get first dibs on the ebay/secondary market for any of these M3 modules that you may need to adapt this to your build(s). We can let the unwashed hordes pick through the parts after we have gotten what we want first :).
I should have a first draft of a public post for our internal review today or tomorrow.
