Dct shifter retrofit f30
JZEE12
Got everything to work but can’t see d/s mode when put into drive should be a coding thing any help ?
JZEE12
I disabled the shifter malfunction warning so It shifts and all works fin
That certainly sounds like a coding task... I don't have an F series, but it seems odd that you aren't getting any codes for shifter?
I removed the shifter malfunction error with coding however just stuck on not seeing the d/s light up when pushing the shifter to the right to engage drive.
besides all else is fine n,r,p, and the shifter works no problem when pulling the paddles down it all illuminates as it should only d/s does not light up when in drive.
would anyone know what kind of coding needs to be done to have the shifter illuminate when going into d/s ?
JZEE12
Isn't that covered in the M3 DCT retrofit threads?
Coding KOMBi and such?
I’ve been searching non stop maybe you can give me a hint as to what thread your talking about ? The F series Kombi has different menus
2,251
805
Does the stock shifter have this feature? If not it might not have that circuit in the GWS.
JZEE12
The stock shifter has the m/s light however it is to the left and not to the right to push it.
normally on an Fx car the shifter should show the middle light and the d/s illuminate when in drive however mine does not.
here are some photos of the problem R,N, park all light up and when the paddle is pressed it goes into the correct d/s mode with the + and - .
But when In drive it just gives backlight but no light on the shifter to say it’s in drive.
2,251
805
I wrote up a pin out for the old M3 knob but that shifter you have is all can bus as far as I knew.
can you explain how you got it to work with your gearbox? Is the GWS still stock with a different knob?
2,251
805
JZEE12
Mine is completely stock I found somewhere ona forum and they got the shifter to stop giving the shifter malfunction message. It kept throwing it every time the car would come to a complete stop. So I did this as far as coding with the BimmerCode app.
  • instrument cluster (Kombi)
  • expert mode
  • 3001- CC_ID_SPERRE
  • CC_AKTIVIERUNG_7
  • Turn it to AUS and not EIN
  • Code done
JZEE12
As far as this diagram the F series of car has this type of shifter connector going to the gws. Could it be a coding thing or a wire thing?
It seems as if the car does not know the d/s that the m shifter has and just defaults to the backlight on the shifter. Because when pulling the paddle down the shifter reacts as it would normally if the car where in manual mode.
staffordshirebmw
has anyone managed to sort this issue as im having the same problem
JZEE12
Hi yes got to the bottom of it seems as if you need to buy a f87 m2 shifter non competition for it to work. Since the problem with the lights is not a coding thing but actually the shifter it self it does not know what drive mode. Only the m2 non comp one will work since there is no drive logic on the m2 non comp just like the f32/f30.
attached is the one I got this is the correct part number and mine works now.
staffordshirebmw
could you please send a video of yours all working and was there any coding needed
ccfj1
65
57
bmw e92 n55 335i Sport manual
Jzee12, do you have the firmware version number for that shifter please mate.
I'm going to have a go at flashing my f15 x5m shifter to the m2 firmware and see if that works. ( also have a spare standard gearshift that i can mix and match to get the dct shiter working)
Also, did you still need to disable the CC message in the cluster?
I'm looking at installing the M cluster too, I have reset the vin and milage already, and powered it up. it all works correctly, bar the FDS and Gear shift icons.
I have a f series bench setup so will be looking at building an emulator for the gear shift display and the FDS icons.
JZEE12
Hello,
Sorry man don’t have the firmware version just bought the shifter and put it in. And yes I did need to disable that specific cc message.
As well as the cluster I have retrofitted the m4 Cluster in my car as well just have the same issue of not displaying the drive function.
Have you had any luck on coding the cluster to display the drive ?
Emulators exist online to allow it to display the correct information, however have not found any available sellers.
ccfj1
65
57
Hello,
Ah ok, no worries, i'll have a look and see what i can do.
right, im hoping to start this soon (weekend will be a start i think). dont expect quick results on this mate, its only a hobby so time is limited.
Im well advanced on the E/F series emulator for power on and flashing modules, I'll just need to work on activating portions of the display when using things like the gear select and FDS.
for the gear select they do, but not for the FDS functions and thats what Im more interested in.
The gear select will be handy so I will be looking at that too.
I will keep the forum posted though, if anyone as a pukka f series M car and would like to take a can bus log when selecting the FDS control and M buttons (mfsw too), as well as the gear selector then I would really appreciate that.
