DAW turbos
Eyelobes
114
61
2007 e90 335i
Thanks for sharing! 50% is much more reasonable for those boost levels. What are you running on the low pressure side? Looks like it is starting to have a hard time keeping up. Also you may want to consider upgrading your FMIC at some point, 25 deg is a pretty big rise on a single gear pull. Not trying to pick your log apart and overall looks pretty clean, just offering advice. I am sure Ken will get it dialed in nicely! Glad to hear they are working well for you.
What would you recommend for a LPFP, I won't ever be running e85 through it so I don't need anything extremely robust.
Blaster3500
296
247
SC
And to have never done anything remotely close to this (most is wheels and oil change), not too shabby to have it running leak free, on the coolant, oil and boost. Pretty fucking proud of myself!
Congrats!! It is definitely a great feeling and half the fun!
Sounds like it has something similar to a fuel-it stage 1 (inline 255 in addition to the stock pump). This should be PLENTY of fuel for what you are doing. One of the pumps must be failing. It may be worth pulling the top hat to check to I would recommend a stage 2 style (walbro 450) bucketed pump. It mainly depends on your goals and what you are doing with the car.
Eyelobes
114
61
2007 e90 335i
I believe it is a 255 replacement to the original. I will have to tear it open to find out. I am looking to probably go for 600whp with meth/water. I would LIKE to hit 500whp on 93 alone, but I don't think that will be possible. Luckily with the LPFP dipping that low, there wasn't a lean condition or a misfire so I'll keep an eye on it and follow Ken's recommendation.
Isn't the 450 a little robust for the stock controller? I've read that 450 and up can burn it out, due to the current draw.
Reactions: Glassreflectionzn54
Blaster3500
296
247
SC
I have run a 450 on the stock controller for years with no issue. You will have some fluctuations in fuel pressure, but that is common. You should be just fine is a single 450 bucketed pump. The additional fueling will come from the meth. You wont run into any lean conditions until the high pressure tanks.
Eyelobes
114
61
2007 e90 335i
Alrighty, man this is adding up lol. So another $400 for the fuel, and possibly injectors down the line (have index10). FMIC @ $550 and want to swap to eldor coils at some point as well.
Blaster3500
296
247
SC
Haha it never ends. If running meth your intercooler will probably suffice.
Eyelobes
114
61
2007 e90 335i
At least with winter coming I won't have to worry about either for a bit. I have a suspicious about my injectors and that's the biggest pill to swallow at the moment.
Your looking for 600 whp on the stage 2s?
Eyelobes
114
61
2007 e90 335i
On an AT that would be absolute Max, 500 I would be comfortable with. I'm not trying to break records on an old ass car. I'd be perfectly happy at 500whp on $1500 turbos on a $7000 car
NoGuru
1,213
596
Just North of Detroit
BMW 335is
Update: The shop that did my install called and let me know what has happened. Rear Turbo seal blew because the VRSF inlet that was only a few weeks old had collapsed. Shawn from DAW replaced the Turbo anyway, free of charge. The shop is also knocking some $$$ off the re-install of the new turbos in inlets.
Oem location or relocated?
Hopefully there realiable at 500whp you don't wanna be uninstalling and installing constantly for stock location twins it's to much of a pia. That's the main reason I went with a top mount single
Glassreflectionzn54
98
36
N54 335i
Warlbro 450 is actually perfect and you need stage 2 to run meth. My tuner told me. The warlbro 525 is the one that need to be with hobb switch. Also if your fmic is not branded it could be a big issue because my buddy had non branded Ebay I intercooler and dyno it and it lost hik power. Be careful. Get vrsf 7.5 asap. Even if your getting meth. Btw I decided to get methanol as well! Hopefully this week will order it!! Cant wait to get to 600 whp
2,197
You can run meth with the stock lpfp. Meth has NOTHING to do with the lpfp system or really the HPFP unless you are spraying so much because you need to use it as fuel. I ran meth on my stock lpfp, plenty have and do.
525 draws too much and is a pain, not worth the gains over the tried and true 450. DIY a 450 for $120 bucks in your stock bucket or buy from @PFS . If you need more fuel than that be prepared to start dropping serious coin.
I agree with a knock off no name IC. Just spend the money once and get the BMS or VRSF 'race' ICs. Go big or go home.
For everyone getting meth kits please get one with all the failsafes built in. Don't spray and pray, Jesus loves engines.
So is anyone else going to post up their balance sheets? Be nice to get to the bottom of that one.
Eyelobes
114
61
2007 e90 335i
So Ken said the turbos hit way harder than he thought they would, hence the 1.5psi over shoot of target. He's dialing it back a bit
Reactions: NoGuru
