Coolant Expansion Tank Fittings?
The Convert
1,487
1,053
I’d love to see HS-79 XRP lines with staubli dry break fittings and -an attatchments on all fluid lines. That’s my end goal...leak free and tool free component removal.
Rob@RBTurbo
626
404
St. Louis, MO USA
www.rbturbo.com
'08 335i, '14 M6, '15 Tundra
We own a machine shop and can make connections however we wish, although the cost would be close to the same (as posted above for the prototyped CNC'd part) it still doesnt make it Dorman cheap!
The Convert
1,487
1,053
Oh. No doubt. Dorman is without a doubt the best bang for your buck. You can’t beat an OE product for that. It’s just not F1 quality or spec like what I would love to do on mine if I ever get around to it.
Reactions: Rob@RBTurbo
NoQuarter
1,662
1,066
Indiana, USA
Z4 35is, 535xi, X5 35i
grr.. Dorman 902-735 is too large also.
This is the one I was really counting for my application.
26922
NoQuarter
1,662
1,066
Indiana, USA
Sent a note to URO parts requesting a 90deg fitting based on knowing the other fitting that is the correct size.
edit: That was fast. Uro doesn't have a 90deg fitting in this size
edit: Dorman does not have a 90deg fitting in this size either
mweisdorfer
I’m in the same boat now you were 14 months ago.
What part number & brand did you end up with?
Please Advise.....
mweisdorfer
