Coding M modules in a non M car
2,267
814
Update: it wasnt fried. I reflashed it to the m3 dsc flash again and it worked fine,just like before. I connected the dtc button to ground and no lights come up on the dash. I check the continuity and its fine. Does the m3 have a different light than the standard 335 kombi? If thats true, how would I check to see if dtc is on or not?
M3 DSC is either on or completely off via button press you’ll be able to tell the difference pretty quickly particularly in wet or slippery conditions. I’m not 100% on whether the dash indicator will work or not
Olza
236
240
BY
BMW 320d
Strange thing, i have after coding only M-KEY menu and there are only POWER (Normal/Sport) and Shiftlights (Off/On).
DKG_CIC, DSC_MENUE and DSC_OFF_CIC aktiv...
2,267
814
You mean coding in the CIC ?
there’s a number of ways to get the menus to appear I recall
RSL
503
Default coded as M3, I have Drive Logic, DSC, Power, Servtronic, Shiftlights. Did you change the VO and code CIC or are you trying to add to a non-M coding?
AzNdevil
604
290
Hong Kong
off topic: does anyone have a m3 cluster with km/h and C faces or sports szl with rain sensor + bottom steering column trim piece they want to sell?
AzNdevil
604
290
Hong Kong
I have an m3 KOMBI but has MPH face....
The faces have to come off when you virginise the KOMBI BTW
i dont mind taking the faces off and i have a r270 already...
i just want one with the stock faces.... or at least stock looking ones that arent so riced out
Olza
236
240
BY
BMW 320d
Interesting idea. Does someone retrofit Fxx gws to Exx?
2,267
814
I didn’t think it would be possible but now that you mention it....
KClemente
309
163
E90 335i
It depends because many of the F series used KCan 2 and when I plugged a new idrive knob on my car all my modules crashed until a restart lol
I’d have to check my wds but do gws’ use KCan?
AzNdevil
604
290
Hong Kong
2,267
814
Closer than we’ve ever been but not quite there yet 😜
2,267
814
A lot of work by others has unearthed all of the messaging that occurs in an M car. Replicating it in a non M is still the issue as the DME plays a significant part. The closest we can get is the IKMOS rom and coding as well as an arduino based CAN shield but still haven’t quite cracked it yet.
LMB335is
301
189
FOB FL
13 335is
Right, I've been running the IKM0S for a couple years now. That damn M3 DME runs all the the good stuff along with the shift light in the DCT cluster.
Reactions: aus335iguy
