Chinesium turbo install
F
Flack304
Guest
Any updates on Viv auto parts turbos? Looking to buyinG a pair!
1,285
779
Has anyone confirmed if the ebay sets are a true TD04 CHRA as claimed?
E92-Ghandi
113
39
2010 335i e92 DCT
Reliability wise? But I pulled the trigger on a pair also hope they last!
I've had them for 10,000 km's so far, didn't face any issues and still pushing strong.
Car is tuned @chrisdfv on 21-22 PSI (93 OCT + Meth) and pulls really good. 579HP (virtual dyno) will be hitting a real dyno by the in a couple of weeks.
Reactions: Glassreflectionzn54
1,285
779
Car is tuned @chrisdfv on 21-22 PSI (93 OCT + Meth) and pulls really good. 579WHP (virtual dyno) will be hitting a real dyno by the in a couple of weeks.
Got any logs you can share?
E92-Ghandi
113
39
2010 335i e92 DCT
Created with Highcharts 7.1.1Amb pressure (PSI)Accel Ped. Pos. (%)Boost (PSI)Boost setpoint (-)Boost target (PSI)Cyl1 Timing Cor (*)Cyl2 Timing Cor (*)Cyl3 Timing Cor (*)Cyl4 Timing Cor (*)Cyl5 Timing Cor (*)Cyl6 Timing Cor (*)Fuel low pressure sensor (PSI)Gear (-)IAT (*F)Lambda bank 1 (AFR)Lambda bank 2 (AFR)Load actualLoad req.MAF Req (wgdc) (g/s)Rail pressure (PSI)RPM (RPM)STFT 1 (%)STFT 2 (%)Throttle PositionTiming Cyl. 1 (*CRK)Torque actual value (Nm)Torque Lim. activeTransmission temp (*F)WGDC After PID (%)WGDC Bank 1 (%)WGDC Base Value (%)MHD version 1.92 IJE0S WBAWB7109APV78115_ije0s_Ghandi_n20_17t_93oct_meth_v3.7.mhd-15-10-50510152025302.0K3.0K4.0K5.0K6.0K7.0K8.0KDatagraphs by SpoolStreet.com
Loading...
wtf2
So I went with 17t turbos from viv
do you guys recommend still balancing and getting them check out by a local turbo service specilist?
also besides getting the turbo kit from ecs tuning what else would I need to complete the install or recommend maintance to do while front subframe is off?
thanks
AWCR1MC
52
32
San Francisco, CA
135i
Glad to see so much info on these chinese turbos. I think I’m going to grab the 19T’s this week since VTT has officially lost my business for good. Has anyone fitted the 19T’s yet?
2,198
thanks
I would for peace of mind, it is small money. The labor to install these is a bitch.
As far as maintenance, you could do your water pump and motor mounts. That is really the only other things in the area iirc. I guess a front sway bar?
AWCR1MC
52
32
San Francisco, CA
135i
It’s the perfect time to do the oil pan gasket as well.
IQraceworks
266
156
Missouri
07' BMW 335i
Any update on the 17t VIV turbos? Are they proving to be reliable? My stockers are starting to smoke.....trying to decide if I want to roll the dice on a set of these chinese turbos.
AWCR1MC
52
32
San Francisco, CA
135i
Viv 17t’s are proven to last. I know of a few people who have been running them for 20k+ miles. I’m running 19t’s I had upgraded and rebalanced by turbo labs.
