Buy this, Not that!
KevinC39
234
118
Here are those lights in use...
I bought something similar from Milwaukee that clamps on to the hood like that. When I open the hood, it blocks the ceiling lights and you can't see anything. The light is a game changer and uses the same batteries as my Milwaukee ratchet
(Not my pic)
3,629
The Milkwaukee light is excellent. It's expensive. How so? Only buy it if you are already on the Milwaukee system. If you buy it as your first Milwaukee electric tool, you will end up buying lots of other Milwaukee electric tools.
Reactions: AzNdevil and Torgus
derekgates
740
375
NW FL
derekgates.us
2011 335is
I LOVE their tools but their lights are very expensive. I snag some of their tools on Ebay but sheesh... I have a limit.
That being said, I tried to save money on an under-hood light and it has been terrible; battery life sucks, can't charge and use it, etc... wish I had picked up the Milwaukee.
Loving the recommendations for the separate lights and the cheaper ratchet set though! My Milwaukee ratchet was not cheap.
NoQuarter
1,662
1,066
Indiana, USA
Z4 35is, 535xi, X5 35i
Those lights i show can be plugged in or on battery. I like to be able to have on all day vs swapping batteries
3,629
The lights are worth it. Specifically the long hood light and this one, which you can run with the small battery (as shown) or a flat bottom battery, which then stands up very well. Use this light all the time. In fact own two of them ...
derekgates
740
375
NW FL
derekgates.us
2011 335is
Oh yeah that one is on my list.
I have the square, short one.. Rover...
It is OK. Shines light everywhere and stands on its own but it is bulky and quite often I can't get it in the spot I want. Also loves to shine right in my eyeballs.
I buy a few tools from https://www.ebay.com/itm/Milwaukee-...k-Light-220-Lumens-Tool-Only-New/333311465804
3,629
Yes buy the one I showed you - solves that problem and very bright. Most used lights I have. And get this kind of battery as well.
derekgates
740
375
NW FL
derekgates.us
2011 335is
Awesome, will do.
Those 6.0s are pricey!
You think the single 6.0 is better than a combo of dual 3.0s for $99? https://www.homedepot.com/p/Milwauk...0-Ah-Battery-Pack-2-Pack-48-11-2412/203630471
I have a 1.0 (1.5?), 3.0 and 6.0 already... One for each tool... haha
[EDIT]: Purchased that small light! Thanks @fmorelli
KevinC39
234
118
@fmorelli Yeah the big milwaukee light is pricey but I did already have a bunch of their other stuff like you mentioned. It's definitely bright and made changing injectors a lot easier.
Anyone have recommendations for a reasonably quiet air compressor? Maybe 30gallons or so.
3,629
Awesome, will do.
Buy the knock off batteries. They work fine. I've bought a number of them. Zero have failed in 3-4 years.
3,629
I wish this thread saw posts a few times a week, so I could be even more broke :grimacing:
I recently purchased a screw clamp driver from Ideal-Tridon for american-sized constant tension clamps. Well made, works well, interchangeable head. https://www.idealtridon.com/catalog/index.html#p=26
Next ... Gearwrench makes a long pick. https://www.gearwrench.com/gearwrench-84012h-long-90-pick.html ... this thing is super handy. One way to use this is to help lift tabs on fasteners, especially those down in the engine compartment. Slide the tip under the tab. DO NOT TWIST the tip and break the tab off. The pick is just tall enough to lift the tab above the detent, so you can wiggle the connector apart without breaking anything. Takes a little practice, but do it several times and you can be a pro.
If you want to see a video of using pick tool in action, Andrew Rodriguez does a great job.
Reactions: NoGuru
3,629
This is not a tool ... ok a chemical tool? But last couple years I've been buying this Car Guys Premium Wheel Cleaner by the gallon. Yeah looks pricey but it works very well. Reasonable, cost-wise, to purchasing individual 16oz spray containers of most any wheel cleaner. https://www.amazon.com/gp/product/B01D94MT2U/
Lurcher
290
168
2012 z4
I just ceramic coated my rims to help. I use this stuff Chemical Guys Diablo Cleaner, but you still have to actually use it :) With it being the rainy season now, washing my car is not a priority as it's getting wet almost daily regardless. Driving in the rain seems to cause enough friction to keep my rims clean too.
Yes, I drive in the rain....
3,629
Here's another tool I highly recommend. Weller Xcelite NN7776VN Long Nose Plier. I own a lot of pliers, and multiple sets, in the garage, my workshop, and the other workshop where I work. Most are Knipex. But this set of Weller pliers is superb. Very precise and most importantly stiff tongs that do not deflect when grasping and twisting - this is a common issue for needle nose, especially when they are this thin. Fantastic for electronics work, and sturdy enough for the garage. I own 3 sets of these.
They don't look like much, nor do they look exciting. But after using a set for a month, I bought two more for all my work shops.
2,197
Given the coloring I assume it is the same Weller as my $100+ simple soldering iron. Quality products. Life is too short for shitty tools.
Granted I barely use the thing which is a shame. Just not much soldering going on any more as I don't often touch PCBs.
