Best aftermarket oil thermostat solution for N54?
MrBlah
62
13
135i, 335i, x5d, r53
Can you provide more information on your oil cooler setup?
I put in a couple of ebay radiators, 19 row (if i recall). an10 in series. The splitter and end plates increased the cooling significantly, I was hitting nearly 295 oil temp in the mountains now I cant get it over 250
now I have oil pressure issues to resolve, high G left turns are not good
derekgates
740
375
NW FL
derekgates.us
2011 335is
now I have oil pressure issues to resolve, high G left turns are not good View attachment 45463
This is my fear of tracking my car... Accusump time?
MrBlah
62
13
yeah researching accusump now, not many have done it I'm not really sure where it will fit in the engine bay
derekgates
740
375
NW FL
derekgates.us
2011 335is
May I present this amazing thread from @Bnks334 ?
So much great info in there as well as plenty of track data. @Asbjorn chimes in with plenty of help as well. :)
MrBlah
62
13
I've already read that thread and that's a n55 which has quite a bit more room over on that side of the engine
Asbjorn
856
607
European, based in China
Z4 N54 DCT
Can confirm, especially trail braking into left hand turns is an issue. Long braking zones also an issue. Accusump is the only solution that is known to work. I have tried several revisions of semi-drying my oil sump as well as baffling it. None of it makes much of a difference. Now I just avoid tracks with many left hand turns all together. My rod bearings did not look too bad when I replaced them though.
wisnia003
Hi I have BMS thermostat Valve in mine. I was wondering - question to someone Who had all types of valves in his hand - is that FTP just BMS valve with OEM spring mounted other way round?
AzNdevil
605
291
Hong Kong
i measured it a few years ago, there is around 5mm difference in where the middle disc thing is located between ftp and bms, the spring doesnt do shit
oem flipped around doesnt open the ports completely
just get a proper external oil thermostat and an oil cooler upgrade
miksebik
68
36
you can have the Mosselman thermostat that starts opening at 85C. Together with 2 19row Setrabs I am happy.
