Thank you !WMI stands for Water methanol injection. If you access to Ethanol i suggest going port injection, and running full E85
Based on your comment about N54 engine remodel,N54s got a major internal remodel after January of 2009. 6 bolt crank and better cams but a worse block for power
Well bmw did the best update to the b58 by eliminating the issue of crankhubs spinning and closing the deck . If you could put a dct behind a behind a b58 that would be ideal for the street in my opinion.Based on your comment about N54 engine remodel,
What will be a better choice ?
Buy N54 manufactured in 2008 ? Or buy N54 manufactured in 2012 {335IS} (With DCT) ?
Because they improved one thing, but unimproved another thing.
Thanks !
Got it sir,Well bmw did the best update to the b58 by eliminating the issue of crankhubs spinning and closing the deck . If you could put a dct behind a behind a b58 that would be ideal for the street in my opinion.
In my country, there are not so much B58.What models with a b58 are available in your country? In America we only got 340 240 and 440 and the supra as well
I'm guessing your ok with rwd?In my country, there are not so much B58.
I must buy car from USA.
I want to do my best and choose correct B58 version or N54 version (This is second scenario).
Thanks !
Yes sir,I'm guessing your ok with rwd?
Well on an N54 with a 6466 700whp dynojet has been made with 93 + DP meth. It is possible but you will be relying on a lot of meth for fuel. You will want a rock solid meth set up.
So,240i and 340i and the supra are all good b58 options id avoid buying the first 2 years of the 240i and 340i. The 335is with the dct is a really fun rwd car as well
Yes,yeah but at the start he said "with just 98RON fuel", hence my negative spin on ambitions.
Yes,
Just I am interested in what is max on 98RON. I am reading a little bit about tune and I know high octane fuel is the key.
Just i want, not to have a wrong expectations.
Thanks !
Well said. Limited by octane having a lower compression ratio makes the engine more tunable to a higher hp without running into know as quicklyFirstly when you are octane limited small things in fuel quality make big differences in what is possible. Also the way fuel is measured is not 100% transferable to the way fuel is used (the machine used to determine RON/AKI etc., is not running direct injection at 3000rpm).
If your local fuel has no ethanol content in it but has the same octane rating as fuel in the US and that fuel contains up to 10% ethanol, you will not get the same results because the direct injection leverages more of the alcohol's benefits than CFR engine (octane rating engine). there are papers written on this.
If your going to buy a car and just put a tune on it, flash or piggyback with no other mods, there are lots of internet posts of dynos for 91/93 AKI fuel from US based users and vendors on dynojets. dynojets are optimistic but they are reasonably repeatable / comparable so there is a huge data set out there for comparison. pick a vendor that sells tunes for both for a fair comparison. i dont know the numbers of the top of my head but i expect < 400whp in both cases. i could not get anywhere near 400whp on 98ron on a bone stock 54 for what its worth.
at the other end of the spectrum if your determined that you want maximum possible hp on cr8p fuel then you need to crunch the numbers on all the upgrades that improves engine airflow at high rpm, i.e. big turbos, head work, cams. i'm guessing the n54 would be cheaper in this regard because its an older platform with more options commonly available for high rpm improvement. so if i were this way inclined and budget limited i would go for a n54.
there are so many other variables to your decision outside of hp relating to the car that the engine is in, dont get distracted by one particular topic. i've procrastinated enough today so last post on topic...
Thanks sir.Firstly when you are octane limited small things in fuel quality make big differences in what is possible. Also the way fuel is measured is not 100% transferable to the way fuel is used (the machine used to determine RON/AKI etc., is not running direct injection at 3000rpm).
Once I buy a car,@gachdavit How much do you plan on investing in this project?
I ask as making the power is one thing, being able to put it down is another.
you forgot the 540240i and 340i and the supra are all good b58 options id avoid buying the first 2 years of the 240i and 340i. The 335is with the dct is a really fun rwd car as well
you forgot the 540
