B58 Ignition Coil DIY solutions
Scorpstan
112
130
like this??
Dumaurier7
689
315
The circles on the right are the injectors and the pipe at the back circled actually rises up to meet the hood so there is a lot of room under it. I already have the coils on hand, tried them a while ago and they fit fine.
BriggTrim
Hi....the existence of the stock loops is a bit restricted at higher than stock strength and your situation will be unique. most say that they will wear out in some measure of miles. That may be 20k, 40k, 60k relying upon various elements. Assuming you run a blend of E85, more flash is most likely required, and so forth
In that sense my thinking is that I was because of redesign and getting a curl that has been tried to convey more flash when I intend to run e55 is a smart thought. My work was to make a moderate transformation choice for myself (and presently others).
www.7pcb.com
Reactions: Dumaurier7
NoGuru
1,213
Just North of Detroit
BMW 335is
I award you no points!
Maybe it is too early for me but I am not really sure what you just said.
687
It is already late here but no comprende either.
I think flash is spark and curl is something on the spring. But thats about it.
Scorpstan
112
130
did some runs with the b58 coils and my setup (resistor in boots) with the SPP223E boots.
with my old bimmerlife kit i had a liiiiittle bit more corrections.
log shows a 850WHP Run
next step is to test them over more gears wot and higher boost level.
1,685
What plugs and gaps is this with? I'm at 0.025" on S55 plugs with my PR kit ~600whp
Scorpstan
112
130
nkg racing sparks 9er cold grade. with 0.020 gap
with other project car which have s55 plugs 0.025" and PR kit too, we run 800whp at moment
pysical
471
108
2009 335xi E90
Awesome to see this working out well. I still need to trim up my resistors and put them in my boots.
Reactions: Scorpstan
Krampus
68
32
Finland
Would there be any recommendations for Europeans on what ignition coil boots could be fitted? For example, a CPBK206 set from Ebay would cost about $ 75 when shipped and including taxes.
Scorpstan
112
130
Order the SPP223E from rockauto
