Are all aftermarket stage2 fuel pumps comparable in quality? (e.g - fuel-It and Spool)
PFS
185
234
The 274 is the same pump as the 267, just a higher pressure relief valve in it. As was pointed out, we use the 274 since it’s appropriate on this platform but if you had a 267 installed, I wouldn’t bother to swap it unless you really have some OCD, are bored, or want to target higher pressures at HPFP/PI inlets.
I regret buying the Fuel-It version.
In stock form the 450 is a barb fitting. Fuel-It cuts that fitting down and threads it for their fitting.
I upgraded to dual 450's and the fittings on Dave's pump didn't work with the other parts I'd bought. So I had to buy another 450.
And my advice is to buy more pump that you'll need. Grow into it. It's such a PITA working in the tank that you'll hate yourself if you have to do it more than once.
I have fittings that will fit on your old pump. If you want one let me know, I have single (for bucketless or external second pump) and double 5/16 QD outlet fittings.
Double pump bucketed systems get TIGHT, not sure about the other guys but we trim the pump outlets and install our fittings for fitment purposes. Lots to fit in a small bucket!
Chris
iminhell1
419
207
Chris
Oh I know about tight spaces. This dual pump bracket from KPD ... needs a serious redesign. It's too bulky to fit through the hole and because of this need assembly inside the tank.
You're guess is as good as mine at how to accomplish that task. LOL
Reactions: PFS
PFS
185
234
Yikes! There is no reason for a double bucketless to be bulky.
Reactions: iminhell1
K_Troopa
16
2008 535xi
I am looking to replace/upgrade my stock E60 pump as well. What did you end up going with?
_Calle_
52
24
Germany
e82 135is
Why is the F90000274 the most used pump? The F90000295 have a higher flow rate (add 100LPH) and need the same Amp.
