ADE N54 5BAR MAP Conversion Harness
AD-ENG
122
140
If 2017 means more boost then we have the solution. This pnp harness allows you to run the popular 5bar brass and stainless body map sensor (up to 60psig). The MAP connector is compatible with a large range of sensors, so it's also a great choice for guys wanting a 3.5bar now and easily upgrade to 5bar later... no harness nor tmaps change needed.
http://www.ad-eng.net/store/p42/ADE_N54_5bar_MAP_Sensor_Conversion_Harness.html
