DIY 335IX built motor/trans single turbo build
nyt
335
2010 335xi
got my subframe back from the powder coater. looks good
Reactions: Torgus and NoGuru
Jern54
310
Netherlands
E91 N54 335i
Did you got a donor crankshaft? Or how you mixed up the nr of bolts in crank and flywheel?
Bummer!
Edit; Entire engine has been changed I see.
Yeah, those are small details in difference with big consequences unfortunately.
nyt
335
2010 335xi
Bummer!
Everywhere I read said the newer engines were 8 bolt. Nope. I had the new engine together before I pulled the old engine out, didn't notice until now.
Not a huge deal, got a flywheel ordered, should be here this week.
Jern54
310
Netherlands
E91 N54 335i
yeah 8 bolt is PRE LCI 06/01/2006 — 08/28/2008
6 bolt is LCI and DCT 01/02/2008 — -
nyt
335
2010 335xi
Added a proper return line for a boost referenced fpr.. just waiting until I get the motor back in and the line connected up front to trim the excess hose by the tank and put a fitting on it. Also removed and blocked off the port for the factory fpr last week and pulled the extra hose out.
I also got the proper flex plate and bolted it up to the engine. Hopefully that's going in tomorrow.
Reactions: NoGuru
nyt
335
2010 335xi
Had some time this weekend, and it was warm enough, so the engine is back in the car. Now I can start chipping away at the little things and getting it buttonned up. "fun" job solo.
Jern54
310
Netherlands
E91 N54 335i
Well done, love the view of fresh coated subframe. Looks very clean.
You don't want to use a engine oil cooler?
nyt
335
2010 335xi
Never needed. My oil temps have always been great. If it ever becomes an issue I'll add one.
nyt
335
2010 335xi
Got a bit done this weekend. I need to set the FPR, and either make adapters or splice the correct connectors onto the adv sensors. Then I just need to put the front bits on and fill some fluid and can start it up.
exhaust all bolted up, and driveshaft...
That nice head games work
Boost control installed
Replaced the 650cc's with the 950cc's.
Brule
393
464
335i 2007 6spd manual
Much respect to you.
I have been watching your build for a while.
Looks like your getting pretty close to driving it. Keep it up. It will be an absolute weapon.
  • Love
Reactions: nyt and SlowE93
nyt
335
2010 335xi
I got the PCV all finished up this weekend, had to drive to three diff auto stores to find one with 3/4in hose.. nuisance.
Car started, sounds good so far. I had a bit of an incident while I was under the car adding trans fluid and the car was running, that wasn't fun.
All of a sudden one of my cooler lines disconnected, I guess I didn't click it in all the way. You can see the size of the puddle post-cleanup. All that pricey atf1 on the floor.
break in oil looked clean...
Little bit of junk in the filter...
  • Love
