335is M3 rear-end (diff, axles…)
DayLater
Hi all, I just bought a DCT 335i and wanted to fit an M3 LSD to it. I’ve done a bit of reading and from my understanding it seems the M3 gear ratio is too different from the 2.56 in the 335is.
I’m in the UK and I’ve just seen a complete E92 M3 rear come up for sale. Only thing is it came off a manual so the ratio is waaaay off.
But I’m planning on switching to a 2.81 ratio anyway, off an older BMW. Will I have any issues in this case?
Any guidance or help is much appreciated with getting this build up and running!
TIA
DirtKurt
179
196
NH
I know there is a 2.81 ring and pinion but is it compatible with the m3 differential case?
The lowest m3 ring gear is 3.15 I believe, the m3 dct uses 3.15 which should work fine with a gearbox flash
