2018 VTT New Product Release Thread
Blaster3500
296
247
SC
1.75" is the OD? What's ID of that hose? (would be same as the turbo housing outlet OD) Just double checking. Thanks!
(and I PM'd on the purchase - already have the outlet covered ... so anyone else with a 135 or Z4 have at it!)
Oops I am sorry I skimmed it and assumed ID. Just the coupler not attached to anying is roughly 1.950 when installed on the outlet roughly 2.050. The actual ID is 1.650 Hopeful this helps.
Just finished up my daily gc 2.0 tune on 93 and to say the least I'm impressed, these gc's are really begining to show how good they are when setup correctly with the right supporting mods.
DCook
274
135
08 BMW e92
In for info as well. I "broke" my motor while running 32lbs. So ill be interested in this, while i do internal upgrades too.
*shakes Chris violently. "WE NEED INFO!"*
Still working on the e85 tune, still a bit to go.
Yes taking it easy on 93, we want a solid clean tune for everyday use and e85 for those odd days I just want to have fun and later blend both tunes on flex fuel map.
Jake@MHD
Nov 7, 2016
1,614
2,080
Philly
Yea MAF g/s is just a calculated value based on various complex models. It's very accurate for stock turbo cars, but beyond that should just be looked at as a number input as an axis lookup to tables.
Jan 31, 2017
395
815
www.hydraperformance.com
2010 135i 6MT
Jake,
I get the impression it is also spot on if you leave BRO, and some other factors stock on an unscaled <22psi tune... Wouldn't you agree?
Jake@MHD
Nov 7, 2016
1,614
2,080
Philly
Jake,
Correct. But again, only for stock turbos. It doesn't take fuel scalar or stft into account for the airflow model, and 19psi on stock turbos is much different g/s than 19psi on upgraded stock frames or an ST, they move a lot more air. Fueling can account for the difference thanks to it being closed loop and having a wide range to add. You see what I mean?
Reactions: Hydra Performance
shushikiary
310
185
335xi
I'm amazed you guys haven't announced anything on the GC+ option.
I just got my set in and looking down the intake side of the compressor its a whole other animal compared to a normal GC. Is it just me or does the turbine look larger too?
