The making of an alcoholic!
Dumaurier7
670
294
is it true that EOS is the only alu intake manifold that can be fitted with the oem airbox. I have e89 z4, airbox is better in design that other n54 cars i beliewe. I do not want any DCI that is for shure.
What is the issue usually. Is it the added fuel rail for PI sitting too high? Is it limiting the space? I believe i can make DIY mounting solution if only there is phisical space under the e89 bonnet.
As seen in the pic it's the only manifold with the threaded bosses for the stand offs which the air box is held on by and because it is designed for the OEM box, the fuel rail is placed low enough to not cause any interference problems with the box.
I have strut brace on my e89. Since i have PI plate now i had modded the airbox fitment , otherwise there was no gap between strut brace and airbox cover.
There are strut braces specifically for the E89 which are made to work with the air box.
And yes. Where can i get eos manifold, shows sold out quite a time now.
Thanks.
I got mine from CES Tuning after couple months of waiting.
Dumaurier7
670
294
These are pics of the flow meter and solenoids, if u look closely , where you see the white tape that’s where the fittings screw into the flow sensor.
Although fully set up I am not getting spray, even when I manually test with the llaptop , I am suspecting a faulty 12v supply to the solenoids so I’ll be investigating as time permits.
