N54 1st time to the track....10.90 @ 128mph!
IQraceworks
266
156
Missouri
07' BMW 335i
I was long overdue to get my car to the track. 07' 335i with the standard bolt-ons, RB 2 turbos at 25psi on an E40 fuel mix, and a custom tune by Justin (V8 Bait). I'm running cheap 265 Firestone Firehawk Indy 500's in the rear....stock e-diff setup.
First pass I knocked out a 10.90 @ 128mph...with a 1.84 60ft time....I was shocked!! I was hoping for mid 11's if I was lucky. That was the fastest pass of the night... everything else was low 11's....I just couldn't get the launches consistent. Either I left to soft and it took a while for boost to build, or too hard and I blew the tires off and had to pedal the throttle.
.....Robs turbos and Justin's tune made awesome power...I'm guessing close to 600hp to get that ET. I'm right at the limit of the HPFP...rail pressure starts to get a little low at the big end of the track.
Overall...I'm pretty happy 😁
IQraceworks
266
156
Missouri
07' BMW 335i
I was just shocked how well the car hooked......I even knocked out a 1.74 60ft time, then the tires broke lose and I had to get out of the throttle. For being so cheap, those Firestone Firehawk Indy 500 tires actually hooked awesome once you warmed them up a bit.
