N54 MHD+ New Tables Talk
Sava666
174
36
Update*
Flashed same map with MHD V3.03 I was using prior to this and throttle corrections are gone…
Update*
Yes. You're right, switched back to v3.05 and everything is fine. No TCs and target boost came to the desired positions.
BEAT_ITN54
34
Update*
setting boost target modifier to 1.0 for the upper range and tweaking the wgdc base and adder has resolved the lower target issue and most of my throttle closures.
Reactions: Sava666
Jake@MHD
Nov 7, 2016
1,594
2,065
Philly
3.0x before 3.09 had some bugs where throttle would not close like it should when using the 3D boost ceiling tables. That is now resolved. You will want to set both boost target modifier tables to 1.0 if using the custom 3D boost ceiling.
Reactions: Sava666
Sava666
174
36
Hi mate. My friend just bought his 335i Euro I8, and his full flash took 13 minutes (map write 55sec) and my 335i US I8 usually takes 23 min full write (map write 2 min). He uses my dcan+otg. But he has Samsung, while mine is Poco f3. How come? )))
Flashes take a lot longer with cheap cables. Does your friend have a proper bimmergeeks cable or wifi adapter?
Sava666
174
36
He used my cable. Its not cheap chinese, and its not bimmergeeks, but it has original internals FT232RQ inside much faster than chinese one and for him it takes only 55 secs to do map write, while mine takes 2 mins with the same cable and otg only difference is he has Samsung S10, and mine is Poco F3. His car is 335i 2008 EU, mine 2007 US.
Sava666
174
36
Guess it's one of a super license features. Believe it's artificially reduced flash time for those who just have a flasher license.
I
I'm certain that isn't true. I have 2 cars and 3 cables. One car has a super license and the other has the basic flasher and logger.
Between both cars write times are identical but the cables make a huge difference. One cable is a basic eBay cable, the second is a bimmergeeks pro one and the third is the bimmergeeks expert gold plated one and the cheap eBay cable always takes way longer (almost twice the time) to flash whereas both bimmergeeks ones are identical in flash time. Same story even with xHP and BMW standard tools.
I don't know how good your phone is but that isn't usually a limiting factor. I'd be shocked if an ebay cable can do a map change in 50seconds, more likely that's incorrect.
Sava666
174
36
I
The facts speak for themselves.
His phone and my cable do 50 seconds.
My phone and my cable do 2 minutes.
Maybe Samsungs have some special ports? )
RSL
501
USB3 vs. your USB2? Could also be controller, drivers or who knows what else. Run some benchmarks and compare. There's no diff between my S7 and S22, both USB3.x.
50-55 secs on cable seems questionably fast. On Bimmergeeks Expert, I'm at 80-85 secs for a short flash. Old cable (OneStop) was about 2:40. Long write was 22 minutes old cable, 10-11 minutes on bg and full write was 40 minutes down to 19.
If yours is that slow on a good cable, wifi would probably be a lot faster.
586
Did anyone update to 3.10 already? seems to be very new. Buddy updated and now cannot login anymore.
Sava666
174
36
Yeah poco f3 is usb3. 55 seconds on samsung s10 I shit you not ))) I was like wtf is happening here?
RSL
501
That's crazy. Gotta be drivers, controllers or some setting, I don't know what else would cause such large differences.
I don't believe a random ebay cable can do a map change flash in 55sec. I'd need to see a video of it being done first. Even cables with the updated firmware struggle to get flash times below 1:10.
Zetra
21
A short flash, with my poco f3 and a Amazon cheap cable plus the OTG adapter does It on 1 min 02 seconds
Reactions: Sava666
Sava666
174
36
Mate, no one told that it is a random ebay cable. Ill take a video for you guys )
Sava666
174
36
Well Id suspect the OTG adapter then. My friend has a cheap Samsung type-c otg adapter. The black one. Whats your otg? Mind sharing a picture? And what are your licenses?
Zetra
21
I have a short otg cable i Will show you tomorrow because is 1:24 hours in Spain and im in bed right now,
I have flasher and mapa packs but i dont have mboost
