MHD 3-port MAC Solenoid issue.
Sava666
174
36
Good afternoon, folks. I wasn't able to find thru the forum. Car is swapped N54, ST Garrett GT40, mv-r wg 13psi springs, 6mt.
I have a problem: I can't figure out which method of boost control I should use when I check the "3 port MAC Solenoid Control" checkbox in MHD.
I have connected everything according to the instructions and flipped pin 7 to pin 25. is it WG valve control (pin 7) connected to some O2 sensor heater (pin 25)?
Now, I'm trying to adjust the boost and make it spool up early. However, I still can't control it, although the log indicates that the signal is being sent.
My question is, with the new "MHD 3-port MAC boost control" option checked, do I have to use the new "Map switch table" from github and "N54 Specific Custom WGDC Control" tables? Or can I stick with the Classic WG control?
Any hints would be helpful.
I have attached the log for reference.
Use any boost control method you want. The stock one is best IMO but the MHD ones are good for beginners.
It looks to me like your have the MAC solenoid connected incorrectly.
Reactions: Sava666
Sava666
174
36
Can you please tell us what happens behind the curtains when you switch to 3-port MAC option? It would be easier if I understand the backstage process. Thanks.
I think they just echo the WG pwm signal on the spare O2 sensor heater output and configure the channel to be the correct signal type for a mac solenoid.
From experience the common failure is how the user connects the mac solenoid. The wiring and vacuum connections are the bit that people mess up.
Kynetic335boost
Pittsburgh PA
07 335i E90 6 spd
what makes you think that by looking at his log? Is it his PID and base being the same?
noorj
140
104
Detroit, MI
'07 E90 335i
About to try this method after using an EBC on my single turbo setup for 4 years, would really look to be able to control boost in part throttle situations (above spring pressure). With mapswitch it seems like the way to go if it works, but I had a bad experience with the original "boostbox" back in 2019.
Anyone else using this?
tms.Abe
Works Flawless. Straight Forward. šŸ‘
Reactions: noorj
