So if anyone ever wondered how the rear damper mounts look like after 11yrs/150kkm, the are quite fine actually. Same for the inner upper control arm bushings. The damper rubber stoppers however not so much...
Also bought some used HR springs and compared them to eibach and oem. Definitely lower. Should also be stiffer as the wire diameter isn't variable, and the progressive coils (those with shorter distance) close first, and then the stiffer rate kicks in.
I will try to run these together with a height adjuster to get the height back to eibach-level rear. Front I will just keep the stock springs.
