Ad: xHP Flashtool: Official thread - ZF6HP TCU Flash
08_335i
371
215
2008 ST 335i
They offer Stage 4 I believe, but I haven't opened that app in a long time. You can set your shift points, however I'm not sure about the part throttle ones based on load or whatever it is.
Currently all that I see is WOT/kickdown on/off shift points that you can edit. I think part throttle/load based shift points will be editable soon. Stage 4 is a track tune.
Cheezy
611
225
Toledo Ohio
So i just need to pull the trigger on stage 3. But can anyone confirm if I need to check kickdown box if I have it off through mhd?
BavrianHawk
2009 335I
I have a question for xHP, I have a 2009 335I that i will be doing a trans valve body rebuild, along with new gaskets and seals. I currently have xHP Stage 3 installed, i was going to do an adaptation reset along with the proper relearn procedure. Do i need to flash back to stock TCM tune before doing the adaptaion reset and relearn or should i leave xHP installed?
Thank you in advance!
1,630
Great question.
Reactions: BavrianHawk
scrllock
267
153
2011 335xi
Last time I flashed (stage2->3), it reset my adaptations as part of the flash anyway. I don't think there's any benefit to going to stock first.
Maniac0908
109
7
07 335xi
Hello, so I just did a single conversion. Should I be running stage 3 v1.5? Or stick with v2.2?
Subwoofer
267
48
I’m not sure about the question of whether you should put back to stock, you’ll have to wait for them to reply.
But if you do the reset make sure you follow it properly, lots of people mess things up!
