Xdrive to RWD
Montegobluee92
I know i may get flamed for this but, im collecting parts to RWD swap my e92 Xdrive. I wanted to create a thread going over the conversion. The goal was to swap to a 7 speed DCT while it was being converted. Im still working on what needs to be coded to get everything to play nicely together. From what im seeing, i may have to swap over the DSC module from the RWD donor. Im not sure if other modules will need to be swapped yet or if the existing modules can be coded. Here's a list that i have so far with more to be added:
Current list:
RWD Subframe
RWD Oil pan
Knuckles
Steering rack & pinion
Steering shaft
Struts
Control Arms
Sway bar & endlinks
Tie Rods
Middle subframe bolts
RWD Wheel Speed Sensors
Hardware:
BMW Suspension Subframe Mount Bolt
Genuine bmw- SKU: BMW-31106850312
    • Genuine bmw- SKU: BMW-31106769907
    • Genuine bmw- SKU: BMW-31106767497
BMW Steering Rack Mounting Bolt
    • Genuine bmw- SKU: BMW-32106773068
BMW Suspension Stabilizer Bar Link Nut
    • Genuine bmw- SKU: BMW-33326768884
BMW Stabilizer Bar Link Bolt
    • Genuine bmw- SKU: BMW-07119903931
Montegobluee92
Just as a quick update, The trans mount is different between the RWD and AWD cars. Working on a solution for that. The idea is buying a parts car that's the same year as my e92. The goal is working ABS and DSC and to have it work the way that it did when it came from the factory.
