Also I wanted to add:
In the application on the bed plate a high torque isn't needed, so you can use a grade 12.9 bolt torqued lightly like previously suggested. But why would you choose that over a stainless bolt that is less susceptible to hydrogen embrittlement and corrosion? There is zero benefit in this application for a grade 12.9 bolt, and if anything stainless is superior in this use case as high strength is not needed.
