Which PI kit are you running?
  • AD-E
    Votes: 2 6.5%
  • MMP
    Votes: 10 32.3%
  • Fuel It
    Votes: 10 32.3%
  • Black Market
    Votes: 7 22.6%
  • EOS
    Votes: 2 6.5%
  • Total voters
    31
Abacus38
643
385
Tampa/Orlando, FL
2007 Ti Ag 335i
Which Port injection kits are you guys running? I'm trying to figured out should hold out for the doc racing manifold or just pick up PI spacer.
The Convert
1,487
1,053
I would hold out for a while. I've had the motiv/fuel-it rail on my car since it came out and still have yet to connect the negative lead on the aic6 to start using it. I was hoping the tuning/integration would get along faster, but still waiting for a truly safe and integrated way to run it before I do, and I'll likely have a fwd facing manifold with integrated PI before that happens.
Reactions: Abacus38
dyezak
1,767
1,518
Plano TX
335is
PI spacer = 2x the potential leak points for boost leaks. I won't even get into PI integration limitations....it's just not the cleanest solution to fueling unless you are running a Syvecs that has full control over both PI and DI.
Abacus38
643
385
Tampa/Orlando, FL
2007 Ti Ag 335i
I'm not worry about integration since I'll be getting syvecs in March when I get my open enrollment commission check. I'm just trying to figured out should I hold out for the doc race manifold or get a spacer
4,340
Youre nuts! I got two of them, its an awesome intake manifold/ PI combo.
Only because I've got the shotgun and don't intend on needing it. Its there if I go big boy power one day though.
I have one and it fits like a damn glove. You can take it out in a snap and installing one doesn't require fabrication like forward facing intake manifolds, as pretty as they are.
Jmw3607
34
15
08 335i e92
seems like alot of people initially purchase MMP PI, but then change their minds due to all the PI kits from MMP for sale on the fb groups lol.
Reactions: devildog0905
4,340
Everyone I know that has tried one had problems with it.
1,573
thought doc race manifold was a no fan kit.
STE92
224
84
E92
Just got MMp Pi kit, going be using it with meth... guess I will report back. Honestly CS is top notch and the kit looks like it will work just fine.
