What are the limits of the stock fuel system on a E85 mix?
4,345
I never really understood why people want to run full E85 at lower power levels unless its merely for ease of use.
Mightbaal
76
12
2008 335xi E90
Safety... E85 105 octane burns cooler like Meth injection. Tunes are usually alittle leaner also for E85.
MDORPHN
196
162
BMW 1M
Sounds great!
I understand that Flexfuel will allow engine to run more timing, but will it also be designed to allow higher levels of boost?
Thanks.
Neil
NoQuarter
1,662
1,066
Indiana, USA
Z4 35is, 535xi, X5 35i
Sounds great!
Thanks.
Neil
Hi Neal,
You should check out the flex fuel threads for more info. But the basics of it is you pick 2 different tunes - OTS or custom and assign them to a low E85 tune and high E85 tune. The flex fuel module simply interprets between them as the E content varies between them.
Jim
Reactions: MDORPHN
3,629
Jim
Yeah, Jim I quoted it you and posted on the flexfuel thread.
Rcboosted2007
902
90
Parts unknown
07 335i
A lot of good info.Good luck with your fuel system.dont push to far into 500hp, for sake of injectors but It looks like you still have room in your setup for more power. Hope to see you break 10s!!
Rcboosted2007
902
90
Parts unknown
07 335i
I havent heard of an upgrade to the factory injecotrs.Factory injectors/system good for 500-550 alone. I upgraded system by adding port injection with 1055 cc injectors and 100% methanol on single cm10 nozzle with assistance of a stage 2 pump. I am however 100% e85
NoQuarter
1,662
1,066
Indiana, USA
nice... you got all the fuel going on here. I did Methanol in the charge pipe few years ago, I really liked it.
Hill'n'toe
37
335Xi
Interesting post.
What could I expect from Stage 2 LPFP, everythig else stock and full e85 ?
Thx
colinod
48
20
2007 e92 335
Interesting post.
Thx
400whp or so on a healthy hpfp. on an e blend i've seen up to 670whp on a 6466 setup with a single 450 intank, all direct injection. the limiting factor is your hpfp
